Home > Technical > Help Required, tailgate issue |
Welcome to the forum common issue have you tried pushing it down directly above the switch then toggle the keyfob - ( close - open ) - it may release that way - good luck . 16MY Estoril Blue SVR.............
Sun Feb 07 2016 10:15pm |
chrisdodds89 Member Since: 22 Aug 2015 Location: Doncaster Posts: 6 |
Thanks Peachy. I will give that ago tomorrow. It used to work intermittently but as now stopped working altogether. At least I can still get in the boot via the full lid |
Sun Feb 07 2016 10:18pm |
The switch historically corrodes - approx £20 for a new one 10 minutes to replace - they can be cleaned up but it means braking the rubber seal - IMO better to replace 16MY Estoril Blue SVR.............
Sun Feb 07 2016 10:20pm |
That's if I get it open hahaha, will let you know how I get on |
Sun Feb 07 2016 10:44pm |
Also try pushing your Landrover logo on your keyfob - This is factory set to open the upper tailgate 16MY Estoril Blue SVR.............
Sun Feb 07 2016 10:56pm |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 |
Some idiot was frantically pushing the button on the lower part of the tailgate while I was clicking the LR logo on the keyfob from a distance (just to allow him to take his stuff out).
Sun Feb 07 2016 11:05pm |
Mine is set to open the full boot lid and now the switch doesnt work I can't put it back to that setting can i? |
Sun Feb 07 2016 11:07pm |
Im sure you can - the instructions are in the owners manual 16MY Estoril Blue SVR.............
Sun Feb 07 2016 11:16pm |
The owners' manual says "push the LR logo on the keyfob while simultaneously pushing the upper tailgate lid switch". The problem is, it only works if the switch works. Regards etc.,
Sun Feb 07 2016 11:17pm |
^^^^^ so without the keyfob - the upper tailgate does not open from the switch - the switch has been replaced & still does not work ? Is there a fuse ? 16MY Estoril Blue SVR.............
Sun Feb 07 2016 11:22pm |
Battery dying on iPad - use the search option on the top banner ' tailgate switch ' loads of info - some good - some bad ££££ 16MY Estoril Blue SVR.............
Sun Feb 07 2016 11:31pm |
Fuse checked OK.
Sun Feb 07 2016 11:47pm |
