Home > For Sale & Wanted > SOLD] Heated Steering Wheel
Heated Steering Wheel removed from late 2012 Autobiography, only removed because I changed Wheel for Sports Grip one.
Fully Working and in Very Good Condition, car has done 30k.
What you see is what you get, there are No Switches or Rear Cowling as used these on my New Wheel.
£145.00 Inc. Delivery UK mainland only.
If you are local you're welcome to come and have a look.
Post #485960 Thu Jan 28 2016 9:15pm
andywatson
Hi Col,
If this can be fitted to my 2010MY RRS (No Htd wheel at present) I would like to have this.
Thanks 2008 RRS 3.6 HST - Stornaway / Black - Current
2010 RRS 3.0 HSE - Nara Bronze / Almond - Gone
2009 RRS 3.0 SE - Sliver / Teal
Post #485997 Fri Jan 29 2016 11:58am
Hi Andy,
Yes, this will fit a 2010 it is also possible to retro fit to a pre facelift.
Post #486007 Fri Jan 29 2016 1:26pm
andywatson
Great thanks Col Mrs W will be pleased Very Happy
Let me have payment details and I will get that sorted, can you let me know what else I need to get it working please?
Cheers 2008 RRS 3.6 HST - Stornaway / Black - Current
Post #486008 Fri Jan 29 2016 1:54pm
ABSport
You will need to replace your clock Spring this sits behind the steering wheel as it has the connections for the wiring from the wheel. Once you change this and fit the new wheel it is just plug and play. No need to enable this modification Thumbs Up
Post #486010 Fri Jan 29 2016 2:22pm
Hi Mark,
Will a 2010 vehicle not already have the later Clock Spring, I thought they fitted them as standard with the facelift model irrespective of whether it had a heated wheel or not. Could be getting muddled and they all have the wiring in the main column harness but not the Clockspring.
Post #486014 Fri Jan 29 2016 2:41pm
ABSport
Hi mate if it's not fitted from factory ie SE model it will need a clock Spring. Mine never had it.
The only way you'll know is if you remove the wheel you'll see the connections on the clock Spring.
Post #486016 Fri Jan 29 2016 4:02pm
ABSport
Good price for the wheel Col. Bargain really. Thumbs Up
Post #486017 Fri Jan 29 2016 4:04pm
andywatson
Thanks Mark,
Any idea on cost? is it a DIY job?
Post #486028 Fri Jan 29 2016 5:38pm
ABSport
Try and get a used one. Yes it's very simple to replace once air bag and steering wheel removed you will see the clock Spring it basically just pulls off once disconnected. Just remember to disconnect the battery and you'll need the air bag hook tool to remove the airbag.
I have one if you need one Col has one as well. You will not regret it the heated wheel in cold mornings is superb. Whistle
Post #486029 Fri Jan 29 2016 5:51pm
This is the one you need LR018556 you can see the extra 2pin socket at the top if you compare with bottom picture.
Wrong One YRC500070/80
Post #486030 Fri Jan 29 2016 6:30pm
andywatson
Thanks guys,
You have PM Col, let me have payment details
Thanks looking forward to toastie hands Laughing 2008 RRS 3.6 HST - Stornaway / Black - Current
Post #486041 Fri Jan 29 2016 7:25pm
SOLD
Thanks Andy Thumbs Up
Post #486063 Fri Jan 29 2016 11:31pm
andywatson
Chuffed to bits, Thanks Col and very well packed thank you Thumbs Up
Will get on to stealers for the clock ring Friday, once my non starting issues are over - hopefully!
Thanks again Col. 2008 RRS 3.6 HST - Stornaway / Black - Current
Post #486510 Wed Feb 03 2016 9:59pm
