Home > Technical > Heater Motor |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
Lazy relay (probably). Try swapping it with another (engine bay fusebox) and see if it cures it. Visiting from DISCO3.CO.UK
Thu Jan 21 2016 4:49pm |
chi Member Since: 15 May 2010 Location: hampshire Posts: 49 |
Hi Lost for Words
Fri Jan 22 2016 5:24pm |
There won't be a spare, if that's what you mean, but, you could swap temporarily with, for instance, the headlamp washer one. Then you'll be able to see if it is indeed the issue. Visiting from DISCO3.CO.UK
Fri Jan 22 2016 5:49pm |
HI again Lost for Words.
Fri Jan 22 2016 5:52pm |
Many thanks to Lost for Words.
Tue Jan 26 2016 1:45pm |
Tue Jan 26 2016 2:10pm |
Deuchars Member Since: 26 Jul 2015 Location: North Wales Posts: 38 |
Can you tell me where the relay is, and which one it is. I have a similar problem thats causing me some grief.... cheers 2008 Supercharged Stornaway Grey, 22inch black Stormers
Tue Jan 26 2016 4:15pm |
On the back of the engine bay fusebox lid there's a diagram with symbols that should direct you to it. Visiting from DISCO3.CO.UK
Tue Jan 26 2016 4:24pm |
