Home > Technical > Mud flaps for 2007 hst help |
Ian.H Member Since: 04 Oct 2014 Location: England Posts: 180 |
The fronts fit straight on no problem.. the rears will need some extra holes drilled into the arch liner (I think, not looked in months) to get them to fit and will probably be a "snug fit" but will be just fine. I haven't gotten around to fitting my rears yet due to health issues last year, but am planning to get them sorted once the better weather arrives and health stuff has been rectified
Thu Jan 07 2016 11:06pm |
Brianx5 Member Since: 30 Jan 2013 Location: AYRSHIRE Posts: 36 |
Hi I had a HST and fitted front and rear mudflaps as was said the front are the same as standard RRS but the back are easy to fit, you will find there is a line that should meet up too the standard bumper but if you remove that and line them up to the HST and drill the holes you will find they are near perfect fit |
Fri Jan 08 2016 12:31pm |
