Home > My Range Rover Sport > Broken Screen |
Landlord Member Since: 26 Sep 2006 Location: Hampshire Posts: 607 |
On motorway Wednesday something hit windscreen - crack appeared bottom centre. Third time in 14 months
Fri Nov 10 2006 12:35pm |
Note to self: steer clear of any motorway that Landlord happens to be on, too much debris! Bad luck mate...
Fri Nov 10 2006 12:46pm |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
Mine needs doing - the crack I have has started to walk this week - I know I should get it done but dreading damage being done - they'll be insured I know but I just could do without the hassle |
Fri Nov 10 2006 1:04pm |
I will let you know how I get on ! Last time on my Shogun they did a good job, so fingers crossed this time. MY10 TDV6 HSE, Alaska White, Ebony with Contrast, Park Heat, Paddle Shift, Privacy, Heated Steering Wheel, Extended & Premium Leather, MY07 TDV6 HSE, Zermatt Silver, Gone ----------------------------- 1964 Austin Healey 3000 2007 LR Defender 2011 VW Tiguan R Line |
Fri Nov 10 2006 1:08pm |
Thanks and good luck! |
Fri Nov 10 2006 1:18pm |
MDP Member Since: 15 Jun 2005 Location: Back in an AUDI Posts: 8598 |
You want to see what efforts were needed when these chaps have to fit a new replacement window screen in a MGF = sorted now ........ but when they 1st came out [ we had number 84 of the track ] Rover had got it all wrong & as soon as you went over a pot hole CRACK ........... new screen please ............ Several times this happened .....until rover realised that a certain rubber mount was not being installed correctly [ or not at all ] during the buil process.
Fri Nov 10 2006 1:37pm |
Yep same in the Elise - thankfully have not had to replace that one yet. Although with my luck will not be long ! MY10 TDV6 HSE, Alaska White, Ebony with Contrast, Park Heat, Paddle Shift, Privacy, Heated Steering Wheel, Extended & Premium Leather,
Fri Nov 10 2006 1:44pm |
TB Member Since: 19 Feb 2006 Location: Depends who wants to know . . . Posts: 5927 |
Unlucky Landlord. That is a big piece of glass to change.
Fri Nov 10 2006 7:43pm |
kam100 Member Since: 28 Sep 2005 Location: In my office doing quotes!! Posts: 4771 |
When my dads rear screen in the 7 went in April.. NOONE had a rear one in stock.. had to wait for one from Germany Bmw to arrive.. good job we have covered lockup round the back of our offices.. otherwise could have been some damage done.. 7'er doesn't fit in our garage at home.. |
Fri Nov 10 2006 7:49pm |
That'll be my luck and reason for putting it off |
Fri Nov 10 2006 8:03pm |
Being in Holland at the moment (and the same place as the last 2 breakages) they take everything so seriously here.
Fri Nov 10 2006 8:22pm |
Havank Member Since: 20 Jun 2006 Location: West Sussex - UK Posts: 691 |
Where about in the netherlands are you, Arround a'dam somewhere?? |
Fri Nov 10 2006 9:03pm |
Oss near Nijmegen. Here on and off for a while.
Fri Nov 10 2006 9:34pm |
To break the record of longest cue of landrovers |
Fri Nov 10 2006 10:08pm |
Nothing better to do tomorrow so might go and sit in the traffic jam MY10 TDV6 HSE, Alaska White, Ebony with Contrast, Park Heat, Paddle Shift, Privacy, Heated Steering Wheel, Extended & Premium Leather,
Fri Nov 10 2006 10:34pm |
