Home > Technical > I'm leaning to the left |
Corns-88 Member Since: 20 Feb 2013 Location: cheshire Posts: 26 |
I seem to have developed a slight lean to the left. You can't see a front to back lean frm the side but the lefthand side (passenger) is definataly lower than the right. It doesn't drop overnight it just sits there. I'm assuming it needs its ride hieght sensors resetting or something or is there something I can do? 07 tdv8 stornoway grey at home tucked up
Fri Nov 06 2015 3:53pm |
smiler148 Member Since: 06 Sep 2015 Location: forfar Posts: 28 |
I had the same issue with my range rover sport when i picked it up.
Fri Nov 06 2015 8:02pm |
PAS Member Since: 30 May 2014 Location: kent Posts: 70 |
I had this ,spent a few hundred at main dealer ,they couldn't calibrate it,they replaced 2 front sensor's ,yaw sensor,took off the 22" and tried it with standard 20",still couldn't calibrate ,the next step they said was to start changing the airbags,at this point I found out about Geoff (disco site)he came round with his IID tool and took him a little while but he got it levelled up for me.been ok since..touch wood |
Fri Nov 06 2015 8:43pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4332 |
Check the rod is not seized onto the link of the suspension arm. If it doesn't pivot, it can cause all sorts of weird suspension issues.
Sat Nov 07 2015 8:55am |
Allycarson Member Since: 04 Jul 2017 Location: Dumfries Posts: 24 |
would seized rods bring on the fail light on the 4x4 panel as if it was a failed sensor mine has a light leen but doesn't get any worse |
Sat Jul 22 2017 6:28pm |
tom0311 Member Since: 01 Apr 2016 Location: witney Posts: 240 |
Had it on my first RRS. Needed a new ride height sensor on one corner and recalibrating. When you lower to access height does it show any wheels lower than others? Mine used to lower to access height OK but one corner would flash red on the 4x4 screen. |
Sat Jul 22 2017 8:40pm |
4x4 screen seems too show ok |
Sat Jul 22 2017 8:51pm |
