Home > Site News & Feedback > SEARCH PROBLEM
CRACKA
Australia 2006 Range Rover Sport Supercharged Bonatti Grey
SEARCH PROBLEM
Hi Martin ?,
Firstly thanks for setting up such a good site for owners of RRS's.
I have experianced an annoying situation when doing a search relating to a specific topic (It this case it was Cruise Control, but there have been others in the past),
When you enter the search then all the posts come up related to the issue. You then select the one you think might be the most relevent to your enquiry. If it doesn't cover what your looking for instead of giving you the option of looking at the other posts on the issue you have to start again and re-enter your search.
I had to do this about 6 times as you only have the title of the post to guide you.
Maybe there could be a modification ? 'Do you want to seach another Post on this topic'?
Over to you and keep up the good work.
Post #476676 Fri Oct 16 2015 8:30pm
muddywheels
Milk Float Man
Use the back key or tab to go back to previous page with list of posts
NOW GONE
MY16 DS
MY10/13 RRSs - Mini One
FL2s
Jag X-type
D2s - MGTF
FL1s
Landcruiser, Mondeo, Escort, Orion, Astra GTE, Xr3i, Renault 5/19/18, Fiesta 1300S, Allegro, Avenger, Honda MTX, Yamaha FS1E
Post #476697 Fri Oct 16 2015 9:33pm
I believe it's a querk of the forum code
Best to use the open in a new tap option on your browser
Post #476700 Fri Oct 16 2015 9:45pm
muddywheels
Milk Float Man
I just hit back button and works fine on phone and laptop Thumbs Up
Search is saved and autofil though if I refresh
NOW GONE
MY16 DS
FL2s
Jag X-type
D2s - MGTF
FL1s
Post #476701 Fri Oct 16 2015 9:51pm
flydive
What I usually do is "right click" on the threads I think might be the good ones and open them in new tabs.
That way I can go through them and still have the search results available '08 RRS TDV8
Post #476719 Sat Oct 17 2015 7:35am
muddywheels
Milk Float Man
Have done this too on computer Bow down
NOW GONE
MY16 DS
FL2s
Jag X-type
D2s - MGTF
FL1s
Post #476720 Sat Oct 17 2015 7:44am
CRACKA
Thanks Guys I give the suggestions a try.
Post #476727 Sat Oct 17 2015 8:08am
Lost for Words
I always use Google - just add "site:rrsport.co.uk". Wink Visiting from DISCO3.CO.UK
Post #476735 Sat Oct 17 2015 8:33am
fkarim
^^^ I do the same. The advantage of using Google with site filter as above is that it takes you straight to the page where your search keywords are found in a multipage topic. Forum search just lists the threads and you have to sift through every page of each topic returned in search results until you find what you're interested in. Current: MY16 RRS2 3.0 SDV6 Autobiography Dynamic, Carpathian Grey & Santorini Black Sliding Pano/Ebony & Ivory 2 Tone
Post #476768 Sat Oct 17 2015 12:32pm
