Home > In Car Electronics > SPEEDO RECALIBRATION |
CRACKA Member Since: 16 Sep 2014 Location: Hallam Victoria 3803 Posts: 170 |
HI,
Tue Aug 11 2015 2:40am |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1061 |
When your speedo reads 100km/hr you're actually at 106.44 km/hr. 07MY RRS TDV6
Tue Aug 11 2015 3:44am |
Yes garrycol that seems about right .
Tue Aug 11 2015 9:07am |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
On later vehicles, it's easy to adjust, but on the earlier ones, I understand it usually causes trouble, and is best left alone. Visiting from DISCO3.CO.UK
Tue Aug 11 2015 9:09am |
I have standard 60 series tyres on my 07 RRS so am going a few km faster than indicated on the speedo but not as much as you. I looked at adjusting the speedo but I found it was not possible - again a silly software design function - should be so easy to do on a digital system. I believe it can be done on the D4 equivalent vehicles.
Tue Aug 11 2015 9:15am |
Garrycol - Yes I have several Navmans but how and where have you mounted it
Wed Aug 12 2015 3:30am |
Really in your case, the only options you have is to mount it on the windscreen or if you do not want to use your current screen above the radio mount it in front of that screen - double sided velcro would do it and when needed you could unzip it to view other functions of the display.
Wed Aug 12 2015 3:59am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4844 |
I would be quite interested in this as when you say later vehicle what year are we referring to and how is it done? as I tried this on a 12plate MY13 car. Although there is a list of tyre/wheel size options listed in the CCF files they are all greyed out at 0% with the exception being wheel/tyre size the car came on. I have tried changing these with both GAP and Blackbox diagnostic tools and it will not allow me to do it. Cheers Col |
Wed Aug 12 2015 8:41am |
By later, I was referring to 10MY-on, but actually, I think I may have got that slightly wrong. It may just be the trip computer/MPG that's corrected easily.
Wed Aug 12 2015 8:58am |
