Home > Orders (L494) > Approved Service Plan |
rigsby Member Since: 20 Apr 2012 Location: Portsmouth Posts: 879 |
Most have managed to get it as part of the deal. Maybe give your dealer a nudge !!! MY16 AUTOBIOGRAPHY Indus silver with some toys
Fri Jun 19 2015 7:42pm |
sacimiddx Member Since: 02 May 2013 Location: winchester Posts: 38 |
yes - worth it for sure
Sat Jun 27 2015 12:32pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4335 |
The dealer is likely to charge around £5-600 for its 2nd service alone, so a little extra for the first 3 services (@ 16k intervals) is a no brainer, even if you have to pay for it. If you do low miles, then it looks as though you will get all 5 years servicing out of them, which is even better value
Sat Jun 27 2015 1:20pm |
Mark_N Member Since: 09 Aug 2013 Location: London Posts: 1102 |
It does of course only cover standard scheduled maintenance and things subject to wear and tear will still cost. Brakes, Tyres, potentially suspension components, timing belts snd so on. But still worth having, especially when you think of what the dealer charges for a litre of oil. Mark
Sat Jun 27 2015 6:43pm |
SVR575 Member Since: 16 Apr 2008 Location: uk & Europe Posts: 1826 |
Does the car have to be serviced only in the uk?, as sometimes mine is serviced in europe. SVR 2018 in Santorini Black. |
Tue Jul 07 2015 9:05am |
myfirstrrs Member Since: 20 Jan 2014 Location: Lancashire Posts: 433 |
The UK is still in Europe, at least for another year or so. |
Tue Jul 07 2015 10:11am |
The small print says the car SHOULD be serviced in the UK, otherwise the plan MAY be invalidated. That leaves some wriggle room but you can be certain their first response would be "No". The plan is not actually administered by LR. Mark SVR in Estoril Blue |
Tue Jul 07 2015 10:26am |
Olly-ibiza Member Since: 23 Aug 2014 Location: Chester/Ibiza Posts: 189 |
Servicing at a main dealer is like painting your rubbish bags gold to impress people, if I had the choice between letting a selection of5 17-18year old apprentices overlooked by one master technician service my car, or a non dealer specialist use genuine parts for half the cost I know exactly what id be doing! |
Tue Jul 07 2015 10:47am |
Depends on the dealer of course. I've just had two attempts at getting the geometry of a 911 sorted out. A widely recommended specialist mis-diagnosed a problem; the second attempt at a Porsche dealer sorted it out and cost less and the two guys working on it were certainly under 30. It would be good to think the LR dealers would be the same but I do accept that's a bit of a leap of faith. Mark
Tue Jul 07 2015 2:10pm |
Thanks Mark, i am sure you are right. SVR 2018 in Santorini Black. |
Tue Jul 07 2015 8:11pm |
