Home > General (L494) > help please to adjust headlights on 2015 sport |
malcolmw Member Since: 05 Dec 2013 Location: United Kingdom Posts: 122 |
The vertical adjustment of the headlamps is pretty easy.
Thu Jun 11 2015 11:01am |
pko Member Since: 31 Jul 2011 Location: norfolk Posts: 193 |
thanks malcolmw. a great help. i'll give it a go |
Thu Jun 11 2015 11:29am |
Rainbow Member Since: 14 Jul 2014 Location: UK Posts: 67 |
If you have high beam assist the lights do not set themselves automatically, the left hand drive or right hand drive setting has to be set up via the instrument panel menu. From the manual:
Thu Jun 11 2015 9:58pm |
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 |
RAINBOW That sounds like the best solution itisme |
Fri Jun 12 2015 8:49am |
Would be good if I had high beam assist, but I haven't. The first paragraph of the instructions re no need to adjust the lights is obviously incorrect. Just ask all the other drivers who I met coming towards me. I've never had any problems in uk. |
Fri Jun 12 2015 9:49am |
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 |
I suspect that if were headlights were set marginally high anyway (and there is a manual adjustment as described above) then you might get away with that in the UK but provoke a reaction on the continent.
Fri Jun 12 2015 1:39pm |
Ok but the extract says no need for mechanical adjustment not that no adjustment is needed. I presume you have checked all of the options in the menu settings just in case the manual is wrong and high beam assist is not actually required (given it is dipped headlights that are being reconfigured) I would have thought. I do have high beam assist so I cannot check.
Fri Jun 12 2015 11:37pm |
Humbug Member Since: 01 Aug 2014 Location: East Anglia Posts: 48 |
Original brochure wrong: left-to-right headlamps have never been standard, only as part of high-beam assist – really annoying as I sat on the train trying to work out how to change something that had been promised but not actually present.
Sat Jun 13 2015 11:49am |
SDV6RRS Member Since: 08 May 2013 Location: Hampshire Posts: 52 |
I had exactly the same issue as the OP. Several trips to the continent and I was afraid to drive at night.
Mon Jun 15 2015 10:51pm |
