Home > General > parking sensor issues |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1048 |
I gave up and removed the fuse - no tone |
Thu Jun 11 2015 9:24am |
PAS Member Since: 30 May 2014 Location: kent Posts: 70 |
mine didn't work,replaced harness from molti-plug to sensors,sorted it,the actual harness gets water ingress too,known for it so I was told |
Thu Jun 11 2015 1:49pm |
deejay Member Since: 23 May 2015 Location: pontefract Posts: 5 |
Just had same problem and did everything you have done. I had no front or rear sensors working so tested rear harness first and all good on continuity then tested 12v supply to rear harness [brown wire on mine] I was only getting between 0.9 and 1.3 volts so when I unplugged front harness I was getting 12v at rear. Tested front harness for continuity all good tested front harness supply voltage 12v all good so I am now scratching head a bit. All my parking sensors were new or nearly new!! Plugged front harness back into sensors and I got a dead short between black and brown wires +ve and Neg Pins 1 and 3 on sensors. One nearly new sensor had a direct short circuit so I replaced that and still had fault so I switched my multi meter to the Continuity Buzzer and got a tone for a fraction of a second between +ve and neg on another nearly new sensor I replaced that and hey presto ,front and rears are working again. So if you have continuity audio buzzer on your multi meter try what I have, also the sensors I bought were cheap Ebay ones which with hindsight may not be the best. |
Thu Jun 11 2015 8:45pm |
vam17hel Member Since: 19 Mar 2015 Location: North Yorkshire Posts: 30 |
Don't remove the fuse marked parking sensor system and tyre pressure monitor as i tried this and got a car that would not start limited gears message on dash display and F came up in sport shift display put fuse back and it started and run up the road reset gearbox thank god |
Mon Jun 15 2015 7:45pm |
