Home > Technical > P0430-00 (E8) Catalyst system efficiency below threshold |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4816 |
Does this help if you can manage to read it, not a very good print.
Sun May 31 2015 4:18pm |
ijwebb Member Since: 04 May 2015 Location: United Kingdom Posts: 15 |
thanks Col, this is all I had managed to find too. It looks a bit extreme in terms of approach including changing the catalytic converters. I'm fairly sure it is a lambda sensor. You would have thought the error code would make it obvious which one, but doesn't seem like that. |
Sun May 31 2015 6:33pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8800 |
The engine banks are A - right, B - left. Might be reasonable to assume that Bank A = Bank 1 and Bank B = Bank 2 in the error codes. Left and right are when sitting in the car facing forwards I believe.
Sun May 31 2015 7:01pm |
To try and confirm i've identified the right one, I swapped the bank 1 and 2 post cat sensors over today so waiting to see if the fault reoccurs on the other bank. |
Mon Jun 01 2015 8:19pm |
Today I got the same fault code back. That's after a couple of weeks and a few hundred miles with no issue. I was rather hoping that if the fault came back it would be on the other bank having swapped over the sensors, apparently not.
Tue Jun 16 2015 5:25pm |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
If it was a lambda Spenser it would say so in the fault code ie bank 1 sensor 1 or sensor 2 depending. Sensor 1 being pre cat. 2008 G4 RRSport TDV8 current
Tue Jun 16 2015 6:01pm |
tom0311 Member Since: 01 Apr 2016 Location: witney Posts: 240 |
Same thing happened to me today. Car driving fine though. Very old thread I know, but I'm curious if OP managed to work out what was up? |
Sun Nov 19 2017 2:29pm |
Yes, I fixed it. Unfortunately by fitting a new cat. had a local garage make for me at a reasonable price. |
Sun Nov 19 2017 2:32pm |
Thanks for replying. Shame it wasn't just a sensor. Did the issue ever affect the car or put it into restricted performance mode? Or did you just get EML over and over? |
Sun Nov 19 2017 2:42pm |
