Home > General (L494) > DPF Regeneration |
robbo770 Member Since: 13 Nov 2013 Location: Aberdeen Posts: 248 |
just go into command shift mod, lock in 2nd gear for a we while, clear its throat None currently
Sat May 23 2015 2:44pm |
Rainbow Member Since: 14 Jul 2014 Location: UK Posts: 67 |
A software fix relating to the DPF on the new model year 15.5 engines was released earlier this month. You might want to check with your dealer if your VIN is in the range for the fix. |
Sat May 23 2015 3:50pm |
peanutbob Member Since: 04 Jul 2011 Location: UK Posts: 585 |
Thanks for the info!
Sat May 23 2015 10:16pm |
