Home > General (L494) > Navigation/road map on instrument panel? |
Chrisr1806 Member Since: 23 Jun 2013 Location: Sussex Posts: 683 |
Mine does it when the sat nav is on. Arrived: MY16 A/B SDV6 in Aruba, Ivory interior, piano black trim, black panoramic roof, spare wheel, blind spot monitoring, mudlaps and more...
Thu May 21 2015 9:13pm |
RRSman Member Since: 10 Feb 2015 Location: London Posts: 1438 |
Mine too - do you have the full TFT speedo screen? |
Thu May 21 2015 9:45pm |
Baco Member Since: 13 Aug 2013 Location: Belgium Posts: 154 |
I don't have an RRS yet, but I hadn't seen this covered anywhere and I did read that some found that they didn't take advantage of this screen enough, so I thought the map data wasn't displayed there like on quite some cars these days. |
Mon May 25 2015 6:42am |
Rainbow Member Since: 14 Jul 2014 Location: UK Posts: 67 |
The feature is useful especially when combined with the head up display option. I often now have the main infotainment screen showing something other than the sat nav map, instead relying on the HUD direction displays, backed up by the junction info displayed in the instrument panel. I've got the InControl Apps option installed in my car and have tried the Sygic sat nav app, however, whilst the navigation side is great, the integration with the car does not extend to showing the junction view in the instrument panel. I found having to look across at the infotainment display much less convenient (and less safe) so I've stopped using the Sygic app and reverted to the standard sat nav. |
Mon May 25 2015 9:26am |
Dave777 Member Since: 15 Feb 2015 Location: Sussex Posts: 485 |
Can you send addresses from your phone to either sat nav? |
Mon May 25 2015 10:16am |
iainm Member Since: 20 Mar 2015 Location: Cardiff Posts: 48 |
As a side, I had HUD on my X5 and the Nav directions stayed on there permanently
Mon May 25 2015 10:27am |
Nope... |
Mon May 25 2015 11:16am |
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1667 |
You can to the Sygic InControl app (navigate to a contact). And whilst you can't (currently) access apps like FindMyFriends, you can also send a route from Apple Maps or Google Maps to the Sygic app, although I've not yet found a way to do this using Siri. |
Mon May 25 2015 11:34am |
Thanks Phil, LR have nearly entered the 21st century! |
Mon May 25 2015 12:00pm |
And no way to navigate to a phone contact via the LR sat nav as far as I can see |
Mon May 25 2015 12:38pm |
JoBonnie Member Since: 20 May 2015 Location: Nieuwpoort Posts: 4 |
Hopefully soon they'll integrate the new InControl Touch Pro like in the upcoming Jaguar XF... |
Mon May 25 2015 1:22pm |
But will it apply to existing owners if they have in control apps? |
Mon May 25 2015 6:12pm |
InControl Touch is an updated screen and car interface, so won't be retrofittable. The apps should be the same in that they should work on existing systems. Never say never though. |
Mon May 25 2015 6:25pm |
