Home > In Car Electronics > Sat Nav Fault. 2005 RR Sport SE |
Mighty Fly Member Since: 08 May 2015 Location: Dover Posts: 4 |
Hi, the Sat Nav seems to have developed a fault. It recognises the postcode of the detination, but seems to be stuck on a particular location, or does not change to where I am going.
Fri May 08 2015 11:29pm |
PHinett Member Since: 21 May 2014 Location: Birmingham Posts: 63 |
Have you got a waypoint setup...I have done this befor it remembers the waypoint until you reach it And will always point you there first before your destination. 57 Reg TDV8 - Java Black - Privacy Glass - Side Steps |
Fri May 08 2015 11:36pm |
Yes, ive tried to delete it but to no avail. Not for any other reason other than i thought it may do the trick. Is there something else i may need to do.?
Sat May 09 2015 2:14am |
I've now figured it out to a degree, but still having difficulty pinpointing the exact location, and direction of the arrows in respect of which way the car is pointing.
Sat May 09 2015 7:04pm |
Eventually managed to sort the problem out and now all is fine.
Sun May 17 2015 12:08pm |
