Home > Technical > headlamp adjustment |
Martin0711 Member Since: 25 Jan 2014 Location: Buckie Posts: 42 |
Open bonnet, look behind headlight unit and on the inner most side of the headlight you will find an Allen key adjustment screw. If I rememer correctly turn ain't clockwise to bring the beam up.
Thu Mar 26 2015 1:25pm |
SVR575 Member Since: 16 Apr 2008 Location: uk & Europe Posts: 1826 |
Great thanks Martin. SVR 2018 in Santorini Black. |
Thu Mar 26 2015 6:33pm |
betarr400 Member Since: 28 May 2017 Location: roma Posts: 10 |
The brucs are two ...... for the lighthouse |
Wed Jul 19 2017 8:40pm |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 405 |
Is this just for height adjustment or does the same work for driving in Europe? Barrie.
Wed Aug 02 2017 2:45pm |
Wed Aug 02 2017 2:56pm |
Thanks Socast. Barrie.
Wed Aug 02 2017 3:08pm |
stagfinder Member Since: 17 Dec 2015 Location: Peterborough Posts: 22 |
for europe there is a small lever that moves up and down at the side of the bulb holder what it does is flaten the beam for europe if that helps |
Tue Aug 08 2017 12:29am |
Thanks Stagfinder. I found the lever after viewing Socast's video but thank you for making the time to reply. Barrie.
Wed Aug 09 2017 10:05am |
