Home > Technical > Help, I'ts gone potty !!! |
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 |
Hi folks, back again, its done exactly the same thing today again everything has gone potty. I took a reading with the bonnet open 12.4, started her up took a reading 10 mins later on tick over of 14.2, how does this sound ?? any ideas. Just to add I drove her 80 miles yesterday so she had a run 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Sun Jan 25 2015 11:31am |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
That's sounding OK. Visiting from DISCO3.CO.UK
Sun Jan 25 2015 11:32am |
thanks for that, have noticed a large plug behind the passenger rear wheel that looks very grubby, is it worth cleaning then a good dose of WD 40..., just trying 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Sun Jan 25 2015 11:37am |
If it's bad, you could try by-passing the connector and see if it helps. Visiting from DISCO3.CO.UK
Sun Jan 25 2015 11:40am |
Robbie Member Since: 12 Mar 2006 Location: Waiting for my old avatar to be allowed back... we miss her! Posts: 73 |
Definitely a CANBUS problem, either poor wiring (most common) or an individual module on the bus. Whilst there are CANBUS diagnostic techniques given how common wiring failures are in the wheel arch and the area leading to the EPB module I would start by a physical check in these areas, plus a check of the ECU for corrosion on the connections.
Sun Jan 25 2015 11:41am |
Would WD40 help or is it going to affect readings and throw a spanner in the works ?? 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Sun Jan 25 2015 11:48am |
It might help from a moisture point of view but I wouldn't use it - Put it on once you've fixed the problem, as protection. You could use some electrical contact cleaner but you need to find the source of the problem.
Sun Jan 25 2015 12:02pm |
Before hacking into anything you could bride any suspect connector with a twisted pair of wires and suitable pins/backprobes. If the problem is intermittent then checking the resistance whilst gently manipulating the connections is a useful technique. If you can see physical damage then it is worth fixing properly as a matter of course as the bus wires are sensitive.
Sun Jan 25 2015 1:12pm |
Thanks again, when you refer to the plug do you mean the one behind the rear wheel, (passenger) ?? if so are connectors good or soldered and shrink wrap ?? 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Sun Jan 25 2015 1:16pm |
Some general info on the CANBUS if it is a while or perhaps the first time you have thought about it:
Sun Jan 25 2015 1:34pm |
Fish Member Since: 29 Jan 2014 Location: Glasgow Posts: 60 |
Thought I would check in again with my tails of woe.
Tue Feb 10 2015 1:02pm |
I wouldn't bother with the dealer if I were you. You best bet would be to get Disco_Mikey over to have a look at it. Visiting from DISCO3.CO.UK
Tue Feb 10 2015 5:14pm |
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 |
+1
Tue Feb 10 2015 5:18pm |
Yeh, i've had Mikey down before doing a few things for me, great guy and service. I only went down the dealer route as i was getting a cheap oil change deal and its local, the interrogation wasn't much on the price.
Tue Feb 10 2015 6:21pm |
