Home > Faults & Fixes > New Crankshaft RRS 2008 2.7tdi |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
End float? That's crank moving back and forth front to back. If the crank moves up and down by 2 mm it and sump would be on floor. Sounds like thrust bearing failure, usually associated with starting a car with clutch pressed so if an auto impossible. Am sure it's possible to refurbish the crank and for oversized bearings to be fitted but probably not cost affective. It does sound like oil supply failing so factor in new oil pump to price. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Sat Nov 29 2014 6:45pm |
If the car has a full main dealer service history, then it may be worth dropping Pete at Customer services a pm. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Sat Nov 29 2014 6:50pm |
Nhlboy44 Member Since: 29 Nov 2014 Location: Essex Posts: 18 |
Thanks for the info
Sat Nov 29 2014 6:56pm |
You will need at lease 5+ posts to be able to use the pm system.
Sat Nov 29 2014 7:16pm |
The garage I went to said approx£5/7 K to replace engine? Seems drastic as might only be crank ? |
Sun Nov 30 2014 8:24am |
Just checked service book and has 3 main dealer stamps and 3 from Ongar garage which is a Land Rover garage but not a main dealer. |
Sun Nov 30 2014 8:27am |
http://www.ebay.co.uk/itm/Genuine-Land-Rov...1c49f69092 In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Sun Nov 30 2014 2:34pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4335 |
£1450
Sun Nov 30 2014 5:18pm |
