Home > General (L494) > Aircon fan always blowing
Nigel Tracey
Switzerland
No matter what temp I set my aircon to the fans seems always to be on.
I tend to have it set at 19.0º and although it does ramp up and down if I switch on the windscreen clear program after that it just blows all the time, not full blast but at a reasonable level. What's annoying is the noise it makes.
Is this usual ?
Post #443448 Sun Nov 23 2014 9:45pm
peanutbob
2008 Range Rover Sport TDV8 HSE Zermatt Silver
In the climate settings you can set the default auto fan speed from min to max. So it can blow either quietly on min setting or on max settings it blows with a bit more gusto on auto. I think there's a medium setting in between as well.
Post #443453 Sun Nov 23 2014 10:03pm
Nigel Tracey
Switzerland
That'll do it.
Thanks will have a look in the morning.
Post #443454 Sun Nov 23 2014 10:05pm
BKHK
Australia
Always run the AC on, adjust the temperature. Don't be tempted to run with AC off. If you do, the system will eventually smell like a gents dunny!
Post #443507 Mon Nov 24 2014 1:21pm
Nigel Tracey
Switzerland
OK found the setting, easy enough and set it to low, this has solved it.
Thanks
Post #443864 Fri Nov 28 2014 9:55am
