Home > Faults & Fixes > Suspension clunck every now and then |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8800 |
Anti Roll Bar bushes perhaps...or the Anti Roll Bar drop links. 2012 SDV6 - it's missing a couple of cylinders
Sat Nov 15 2014 5:48pm |
PAS Member Since: 30 May 2014 Location: kent Posts: 70 |
hi paul,i've done my wishbones and ARB with new brackets ,mine made very similar noises after doing this.this afternoon between showers i fitted mass dampers and it has cut the noise down so much,can't quite believe it.p |
Sat Nov 15 2014 7:05pm |
ccmpaul Member Since: 09 Nov 2014 Location: Middlesbrough Posts: 4 |
Where can I get the mass dampers? |
Sat Nov 15 2014 9:43pm |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
It will be your lower steering U/j that is worn, I had this on a few now, its only noticeable after the arms have been changed. Not a big job, parts around £90.00
Sun Nov 16 2014 9:19am |
hi Flack, do you mean U/J as on the bottom of the steering column or track rod end type joint? |
Sun Nov 16 2014 11:46am |
mass dampers from main dealer ,£70 ish .hi flack ,I guess this mean I've just hidden the noise by putting the damper's on.p |
Sun Nov 16 2014 3:05pm |
