Home > Technical > Pre heater |
fkarim Member Since: 14 Apr 2012 Location: London Posts: 2216 |
It should come on automatically when you start the car and the outside temprature is <= 5 deg C. Sometimes it needs a reset if it fails to fire up in a few attempts.
Tue Nov 04 2014 12:18pm |
Wayneclarke Member Since: 16 Jun 2014 Location: kent Posts: 394 |
It's a diesel but I couldn't see the pipe your talking about I will have a look under the bonnet later when I get home now I know where to look haha |
Tue Nov 04 2014 12:23pm |
Edited above to add the diagram I found in another thread. And a photo from Disco3 here:
Tue Nov 04 2014 12:26pm |
Thank you I will have a check and post my results |
Tue Nov 04 2014 12:31pm |
Ok so just checked under the bonnet and there it is now i know what im looking for, so i just need to wait for it to get cold to see if it kicks in |
Tue Nov 04 2014 1:36pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8861 |
Mine fired up this morning for the first time in months. The smell gives it away. Often it'll smoke a bit too if it hasn't been run for a while. 2012 SDV6 - it's missing a couple of cylinders
Tue Nov 04 2014 5:04pm |
Oh right ok yeah outside temp this morning when I went to work was 6c so thought if I had one it would have started but no lights to say it was on or no smell |
Tue Nov 04 2014 6:36pm |
mrfixit Member Since: 23 Dec 2010 Location: Bolton Posts: 705 |
Guarantee it will need resetting,I recall being told if your low fuel light comes on 3 times it locks the heater out.Seems madness to me,but hey it is a range rover |
Wed Nov 05 2014 7:54am |
Yes, low fuel light 3 times when the temperature is also low enough to require the FBH and it locks up. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Wed Nov 05 2014 8:09am |
Is it a big job to get it reset |
Wed Nov 05 2014 8:17am |
You need a diagnostic tool to reset it. A dealer or independent can do it for a fee (no idea how much they will charge but shouldn't be a fortune). Or you can invest in a BAS product (search the forum for "BAS FBH Controller") that allows you to reset in addition to remote operation. Or spend even more to get the IIDTool which does this and a whole lot more. But first of all I'd wait to see if it really isn't working. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Wed Nov 05 2014 9:05am |
dodby Member Since: 30 Dec 2013 Location: derby Posts: 7 |
take a look on the disco3 site, in their wiki there is a section on the fbh and shows a possible cheap reset |
Wed Nov 05 2014 11:04pm |
