Home > Faults & Fixes > whistle on accleration
kg
Hi There
I have just bought a 2005 rrs and have noticed that on acceleration there is a whistle noise which seems to come and go mainly noted on acceleration. Any ideas as to what this maybe?
[/list]
Post #438032 Sun Sep 28 2014 1:33pm
Paddi
Hi, how loud is it? Very slight might be OK - my TDV8 has always had a slight whistle. It can be a leak somewhere around the intercooler pipes or even on the charging side of the turbo. If it is loud it could be indicative of failing turbo bearings causing the turbo fan blades to touch the housing. You would only hear that on boost I think. 2008 MY Java Black TDV8 HSE
Post #438068 Sun Sep 28 2014 8:09pm
Dan Stevens
Australia 2006 Range Rover Sport TDV6 SE Zermatt Silver
check all air pipes are tight.
i had a loose pipe after the airfilter had been changed and it was sucking in there under boost
Post #440061 Tue Oct 21 2014 1:11am
