Home > Technical > Leaking coolant - was "RRS SC intercooler" |
frostmotorsport Member Since: 14 Apr 2014 Location: Wellington Posts: 79 |
Hi,
Mon Sep 22 2014 1:19am |
CRACKA Member Since: 16 Sep 2014 Location: Hallam Victoria 3803 Posts: 170 |
Just saw your post. How did you go with finding out what it was??
Fri Oct 24 2014 4:01pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8849 |
The Supercharged engine uses a pair of air-to-liquid intercoolers sat on top of the engine, either side of the supercharger. The coolant is cooled by a radiator in front of the main engine coolant radiator. 2012 SDV6 - it's missing a couple of cylinders
Sun Oct 26 2014 9:12am |
Thanks RRSTDV8 - I suspected that the RRS used a air-water IC.
Sun Oct 26 2014 11:27pm |
So, another 2 (small) puddles of orange coolant on the garage floor and a "low coolant" warning on the dash.... Hmmm.
Sun Nov 09 2014 8:31pm |
USAFBuckeye Member Since: 24 Feb 2013 Location: Il Posts: 60 |
What ever happened with this? I'm having similar issues and can't seem to track down the leak. It's not from a hose or another obvious source. I suspect the radiator but can't get my eyes on it. '12 RRS SC
Sun Apr 12 2015 5:01pm |
Sun Apr 12 2015 5:02pm |
I haven't had a chance to do a pressure test yet - busy trying to work and make a dollar sadly - I will get around to it at some stage soon. I still suspect my overflow bottle, as I've seen threads where they can leak.
Mon Apr 13 2015 2:59am |
nrosenbe Member Since: 24 Aug 2015 Location: texas Posts: 2 |
Did you ever solve this ?
Sat Sep 17 2016 10:26pm |
Turned out to be a bad supercharger inter-cooler for me. '12 RRS SC
Sun Sep 18 2016 6:17am |
Thanks, how did you diagnose it ?
Sun Sep 18 2016 4:54pm |
Yes it was the aux radiator. It had a small leak at the bottom of the core. Easy to replace just hard to get to. '12 RRS SC
Sun Sep 18 2016 6:56pm |
