![]() | Home > Technical > One touch window lowering not working |
| fkarim Member Since: 14 Apr 2012 Location: London Posts: 2216
Looks like they need resetting. Check the manual for instructions to perform a reset but I think it is done on each window by fully closing it and then holding the switch in the close position for a few seconds. |
| PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796
^^^^^^ that guy is good |
| Sag Member Since: 08 Jul 2009 Location: Leicester Posts: 564
Cheers guys, will give it a shot |
Apparently "one touch" only works on the driver's window in your model. From 2006 handbook:
| V8SC Member Since: 29 Oct 2011 Location: Hampshire Posts: 145
Sag, one touch only on drivers door for 06MY but its as fkarim says......
Thanks for all the info guys - tried numerous times with no luck |
| W18ODY Member Since: 31 Aug 2014 Location: north east Posts: 87
Just done this with mine and sorted it |
| stealth Member Since: 09 Jul 2014 Location: Hampshire Posts: 30
Yep driver only on 2006 |
| Andyjay123 Member Since: 22 Aug 2014 Location: London Posts: 698 |
FKARIM
