Home > In Car Electronics > interior alarm |
rigsby Member Since: 20 Apr 2012 Location: Portsmouth Posts: 879 |
If I remember correctly you press the lock button twice within 3 seconds to disable the interior sensors MY16 AUTOBIOGRAPHY Indus silver with some toys
Tue Sep 09 2014 9:21pm |
Yes, that's right. Bodsys Brake Bible
Tue Sep 09 2014 9:52pm |
looneyfitter Member Since: 13 May 2012 Location: liverpoool Posts: 212 |
on the remote? really? i thought that was dead lock.. i always double press |
Tue Sep 09 2014 10:45pm |
thanks |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 919 |
I was under the same impression........ Double press to arm the volumetric and perimetric alarms, I think it's time to check the Oracle, failing that the handbook mightier dusted off.! 2010 RRS, TDV8
Wed Sep 10 2014 8:50am |
frostmotorsport Member Since: 14 Apr 2014 Location: Wellington Posts: 79 |
nope. press once and the lights flash 3 times to indicate that the perimetric and movement sensors are armed. Double press to lock without those armed. Every home should have one!
Wed Sep 10 2014 11:06am |
Just checked through the manual and it states, press the lock button once briefly, this will single lock the vehicle and prevent the doors from being opened from the outside ( they can still be unlocked and opened from inside). The perimetric alarm is also turned on.
Wed Sep 10 2014 4:30pm |
