Home > Technical > Rear door lights
Sirrel Squirrel
Rear door lights
I have a MY11 and I've noticed that the little lights under the rear doors don't turn on like the front ones do when you open them. Do they need to be enabled somehow or just a blown fuse?
Post #434123 Mon Aug 25 2014 10:29am
whippetman
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Think you have to switch them on manually Question
Post #434126 Mon Aug 25 2014 10:58am
Sirrel Squirrel
How'd you do that?
I mean the ones that are underneath the doors that'd light the floor up outside the car when the door is open rather than the reading lights.
Post #434127 Mon Aug 25 2014 11:00am
Bladeboy
England 2005 Range Rover Sport TDV6 HSE Siberian Silver
Have you had it from new? If not maybe the previous owner tried to change the bulbs and lost the wire- happened to me when I changed mine. Pull the door card away and you'll be able to see if the wire's attached
Post #434129 Mon Aug 25 2014 11:12am
Sirrel Squirrel
Not had it from new, I'll pull the door card off and have a look. Cheers
Post #434131 Mon Aug 25 2014 11:24am
