Home > My Range Rover Sport > What a load of old fanny |
Who did you buy it off - Del Boy some of those issues sound almost normal with these vehicles others are less covered issues - I'd be off if I was you 16MY Estoril Blue SVR.............
Sun Jul 27 2014 8:30pm |
hoppy_70 Member Since: 28 Mar 2009 Location: United Kingdom Posts: 437 |
6. This happens if you try and lock it with one of the doors, boot or bonnet not fully closed. The car pips to warn you. Range Rover Sport HSE DYnamic SDV6 Velocity blue 2020 MY
Sun Jul 27 2014 8:33pm |
W33 RRS Member Since: 21 Aug 2010 Location: Carlisle Posts: 68 |
Sometimes my horn sounds when I try to lock it with the fob but it turns out I haven't closed one of the doors properly.
Sun Jul 27 2014 8:35pm |
Damn someone got there before me
Sun Jul 27 2014 8:37pm |
A newer - non official Sat Nav disk defaults to Belgium - remove it then reset it to Uk - it may then stay there 16MY Estoril Blue SVR.............
Sun Jul 27 2014 8:41pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4335 |
Other than 1, 4 and 7, fairly common/easily sorted issues |
Sun Jul 27 2014 10:33pm |
codfather Member Since: 13 Feb 2010 Location: ayr Posts: 1171 |
Is no7 not "follow me home" courtesy lights, if you have your main lights set to auto, they will stay on for 10,20,30 seconds , you can disable that through the dash settings or don't use auto light setting.
Sun Jul 27 2014 11:04pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8844 |
A number of those "issues" do sound like the result of not reading the manual as pointed out by others above - some of them are features that can be adjusted by the driver. 2012 SDV6 - it's missing a couple of cylinders
Mon Jul 28 2014 1:07pm |
Steviesport Member Since: 15 Jun 2014 Location: North Lanarkshire Posts: 52 |
Yes some clown from Geordie shores that's 2 off my private sales in Newcastle and my funking last |
Mon Jul 28 2014 1:32pm |
Most off them sound like user settings not set any likes off lazy entry home lights horn sounding when door open |
Mon Jul 28 2014 1:41pm |
Marsie Member Since: 20 Jul 2011 Location: sheffield Posts: 375 |
On my steering column there is a switch (like a ford granada electric mirror switch ) that alters the column. If you turn that between one setting and the other it alters whether the seat moves or not when getting in/out
Mon Jul 28 2014 11:06pm |
sparky8181 Member Since: 02 Nov 2012 Location: West Midlands Posts: 588 |
Funny how some of these are convenience settings yet you see them as faults..........maybe you should fill in the next R&D survey that Land Rover sometimes send round here, it appears you have different opinions MY07 TDV6 HSE Stornaway & Ivory
Tue Jul 29 2014 8:23am |
Always a smart arse on forums ain't there thanks for taking time to reply none off these features are set on the car so any arse hole would think they shouldn't come on as I have stated none off these settings are set so they are meant to come on are they ? |
Wed Jul 30 2014 12:10am |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1936 |
Stevie
Wed Jul 30 2014 6:11am |
