Home > Faults & Fixes > tdv6 missfire
gazzc
2005 Range Rover Sport TDV6 HSE Siberian Silver
tdv6 missfire
my tdv6 has a missfire and is in limp mode ,i have had codes read and there po20d p132b and p0048 any help would be much appreciated,it has had 1 new injector Question silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Rimini red rrs 2.7 tdv6 steps. Full c code. Recon engine!!loved but!gone ,thank god !!
Gone rr sport supercharged. Loved but 11mpg !!!
current,triumph stag mk2...current bmw 325 sport convertible
Post #430629 Tue Jul 15 2014 6:07pm
gazzc
anyone silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #430721 Wed Jul 16 2014 5:16pm
marcspark
Hi GazzC Censored these engines really are made to Censored Censored Censored Censored off Big Cry Just checked on my Autoenginuity codes for the Code P0048 comes back as Turbo boost control solenoid Circuit High.
P020D Doesn't come back with anything but P020 comes back with Intake Camshaft position actuator circuit open bank 2(can't remember if diesel has it)
P132B Doesn't come back with anything but P132 comes back with O2 Sensor circuit sensor high
Strange how it's started to do this just when it's turned hot Evil or Very Mad Hows your battery? is it getting and holding full charge?
Did you get my PM?
Hope this info helps Thumbs Up
Post #430739 Wed Jul 16 2014 8:36pm
Disco_Mikey
P020 I believe is an injector related code, either at its max/min limits
P132 is a turbo fault code
P0048, not sure but may be related to airflow, given the above turbo fault
Post #430750 Wed Jul 16 2014 10:34pm
gazzc
P020d is saying injection timing malfunction bank 4 but what could that mean silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #430766 Thu Jul 17 2014 6:19am
gazzc
mark pm you back mate silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #430767 Thu Jul 17 2014 6:37am
gazzc
mikey what does that mean injector at max/min limits,if i pull the plug off number 4 and 5 injector and plug them back in it runs on 6 for a few minutes then number 4 goes off again Question silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #430828 Thu Jul 17 2014 6:33pm
Disco_Mikey
The injector compensates to keep the engine running as smooth as possible.
It it reaches its max/min limits, it cannot compensate any further, and so logs a fault
You need to be careful pulling the plugs off when the engine is running. Can overload the injector capacitors, and Censored the PCM
Post #430845 Thu Jul 17 2014 10:06pm
gazzc
anyone know if there is any good tdv6 fault finders in my area [merseyside] silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #430997 Sat Jul 19 2014 6:16pm
Neil,C
England 2005 Range Rover Sport Supercharged Zermatt Silver
http://www.bellautomotive4x4.co.uk/
That's who I use, they've always been spot on. Hope it helps. Smile
Post #430999 Sat Jul 19 2014 6:27pm
gazzc
Cheers I will give them a call silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #431003 Sat Jul 19 2014 8:20pm
Neil,C
Your Welcome Thumbs Up
Post #431005 Sat Jul 19 2014 8:43pm
