Home > General (L494) > Won't open from the inside with the handle?
somchie
Sweden 2013 Range Rover Sport SDV6 Autobiography Santorini Black
My car is setup to be locked when driving, but now it won't open when I pull the door handle (from the inside) now and then. I have to press the "unlock" button and then pull the handle.
Anyone else having this issue? Range Rover Sport SDV6 Autobiography Dynamic -14
Defender 110 SW LXV -14
Range Rover 5.0 Supercharged -10
Post #422861 Wed Apr 30 2014 2:27pm
Mark_N
Sounds like a loose electrical collector inside the door. There will be a switch or sensor which tells the car the interior door release is being pulled and that is not working reliably. Time for a visit to the dealer... Mark
SVR in Estoril Blue Thumbs Up
Post #423061 Fri May 02 2014 5:54am
andman
Andorra 2011 Range Rover Sport 3.0 TDV6 HSE Fuji White
Same happened on my recently sold MY12.....also wouldnīt sometimes open from the outside as well on passenger door and had to go through the same process
A morning in the dealers resolved it.....
Thereīs every chance itīs still the same part they use now... 2014.5 SDV6 AB Dynamic ... Fuji /Santorini Pan roof and 22's
2013 Porsche Boxster S 3.4
2014 Audi A3 S line Quattro
Post #423063 Fri May 02 2014 7:15am
somchie
Oh, it got worse now.
Tonight pressing the "unlock" button didn't work, it was still locked and it didn't work to open the door from outside.
Locking and unlocking with the key fob worked.
I guess I'll call the dealer on Monday.
Still love the car though! Smile
Meanwhile, I'll have to drive the RR S/C. Could be worse Smile Range Rover Sport SDV6 Autobiography Dynamic -14
Post #423178 Sat May 03 2014 8:42pm
andman
i sure wouldnīt risk it if itīs happening on the inside too......
Back in the early 90īs I had a 928 with a faulty alarm that immobilised the car locked the windows and doors with the alarm whaling
sitting right in the middle of an intersection and bus lane.....huge tailback and some very amused motorists laughing at me... some pretty Censored off too.... AA got me out after an hour stuck in the car...
let us know the dealers diagnosis... 2014.5 SDV6 AB Dynamic ... Fuji /Santorini Pan roof and 22's
Post #423180 Sat May 03 2014 8:50pm
somchie
Well. The car is not booked for next Tuesday.
It was not a known issue with the new Sport they said.
However, I found out about a new "recall". "Valet-mode"-issue, entering the 4-pin code to exit valet-mode apparently doesn't work. So I guess we should try that Smile Range Rover Sport SDV6 Autobiography Dynamic -14
Post #423239 Mon May 05 2014 8:06am
