Home > General (L494) > Panic button on key fob
Funduro60
Belgium 2013 Range Rover Sport SDV6 Autobiography Fuji White
After getting my new RRS AB I started reading the manual and getting acquainted with all the various stuff. I tried operating the panic button on the key fob and no do - didn't work. So I took it to the agent afterwhich I was told that since I live in Belgium its illegal to have this in the Benelux countries. Would you believe this? Some stupid politician for some unknown reason decided to make a useful protective tool as illegal. I told the agent that I wanted to have this switched on as I will be taking my car to my original country of Malta. He was told by LR UK this is not possible. Why not? They blocked it so they could be able to unblock it is my line of reasoning. Anyone from Benelux countries here has the same problem and a possible solution?
Post #422360 Sat Apr 26 2014 5:13am
andman
Andorra 2011 Range Rover Sport 3.0 TDV6 HSE Fuji White
Solution.....
Is mace legal in Benelux ??? Very Happy 2014.5 SDV6 AB Dynamic ... Fuji /Santorini Pan roof and 22's
2013 Porsche Boxster S 3.4
2014 Audi A3 S line Quattro
Post #423042 Thu May 01 2014 9:43pm
Funduro60
Lol good one - but joking apart this is really stupid of Land Rover. If you are in your apartment and you can see your car and you see someone snooping around the panic button is useful. If they programmed it they should be able to get over it at clients' request especially when I am gonna export the car to another country.
Post #423059 Fri May 02 2014 3:40am
andman
That should of read ... Malta , of course.. !!
If itīs been blocked... then logically it can be unblocked....
If itīs software... it can possible be re written...
If itīs hardware .... maybe it genuinely canīt be altered.....
If you really want this done..... ask why it canīt be unblocked and donīt settle for a simple no it canīt be done..
Itīs one of the problems though of buying a car for export and not buying in the country you intend to use the car... 2014.5 SDV6 AB Dynamic ... Fuji /Santorini Pan roof and 22's
Post #423062 Fri May 02 2014 6:11am
mse
Its probably just about resetting the car to another territory Mike
2014 Facelift Discovery
Post #423681 Thu May 08 2014 5:27pm
