Home > General (L494) > Speed Camera alerts on SatNav |
Mark_N Member Since: 09 Aug 2013 Location: London Posts: 1102 |
I run a TomTom Go in parallel which provides much better navigation and live traffic response as well as speed camera warnings and, in Italy at least, average speed display on those new pesky measured sections.
Sat Apr 12 2014 6:19am |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1738 |
Does it support "Import POI's "? MY MY13 old shape does and I use that. 2023 P440e SE Dynamic on order -cancelled 2022 HSE Dynamic P400e 2017 Discovery 3.0 HSE Silicon Silver Nimbus interior and a few extra toys SOLD 2013 HSE Black, Orkney Grey, Ebony Seats and Ivory Interior SOLD 2006 HSE Plus a few other cars inbetween! |
Sat Apr 12 2014 8:37am |
You should be able to load a file as personal Points of Interest.
Sat Apr 12 2014 9:28am |
Funduro60 Member Since: 12 Apr 2014 Location: Brussels Posts: 26 |
I think I can import files - I have to check this out as haven't had the car for more than 12 hours. Any idea from where I can find such a file for the Meridian system on the RRS? |
Sat Apr 12 2014 9:30am |
I subscribed to these guys...
Sat Apr 12 2014 9:40am |
Thanks - it sure does look a bit daunting for me as I am a newbie to this. Also I cannot find the Meridian system. Can you direct me to which file I must download and if this is compatible with the Meridian system? Thanks for the patience. |
Sat Apr 12 2014 10:06am |
Yes it does |
Sat Apr 12 2014 10:21am |
http://www.pocketgpsworld.com/modules.php?...er=SideBar
Sat Apr 12 2014 1:51pm |
Dickie Member Since: 27 Mar 2013 Location: Hampshire Posts: 200 |
It does work from PocketGPS although I find with limited use. The reason being that all the POIs load ok but in order to have any kind of notification that you're approaching a camera you have to have a route programmed in and the voice guidance on. Only then does it bong/chime (in one of only 3 simply awful doorbell sounds) when you're close to it. I rarely have a route entered as usually know roughly where I'm going and I certainly don't use the voice guidance part so the only use for having the POIs for me is if I use the satnav screen as part of my instrument reading 'scan' to see if there's a symbol approaching. SOLD - 15 plate Estoril SVR
Sun Apr 13 2014 4:17pm |
Meridian make (or at least design) the sound system, not the satnav which I think comes from Denso though where the mapping comes from I have no idea. Mark SVR in Estoril Blue |
Sun Apr 13 2014 6:14pm |
Thanks mate - it works a treat and also reduces the sound of yuour audio when the chime comes on. There are only 3 chimes to choose from and ALL suck badly. Would be better if the chimes would be replaced with the sound of a camera shutter like I had in my Volvo xc60 but at least it works well. Also the faster you drive the earlier the chime goes off. Good work and thanks. |
Mon Apr 14 2014 3:22pm |
