Home > Technical > Whooshing Noise when excellerating.
Sandra
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Hi all, can anyone help please.
I have noticed over the past week or so, that when sitting in the car with no radio on, that when I rev the car I can hear a whooshing sound coming from the drivers side dash area, obviously it's coming from the engine but what can the noise be. Should I be worried!!!
Any ideas would be really helpfully
Thanks
Bow down
Post #416169 Sun Mar 02 2014 9:06pm
aljo
Hi Sandra
Cheapest option is Just keep the radio on Thumbs Up Whistle
Seriously though when you say whooshing ! does it only make the sound when cold
is it coming through the air vents or lower down from the footwell in the pedal area ?
is it an air type whooshing or ?
your fan maybe Rolling Eyes
Post #416172 Sun Mar 02 2014 9:18pm
Sandra
It sounds like it's coming from the top right hand corner of the dash. We had the blowers switched off also so we could hear properly. I think it's like an air type whooshing but hard to tell, it's not the fan because it was all switched off. But it like it whether the car is cold or running a while.
Post #416174 Sun Mar 02 2014 9:22pm
aljo
are you getting any smoke out the back at the same time as revving ?
thinking inter cooler pipe maybe split Rolling Eyes
Post #416175 Sun Mar 02 2014 9:28pm
Sandra
No smoke at all.
Where is the inter cooler pipe, is it easy for me to check?
Post #416177 Sun Mar 02 2014 9:39pm
aljo
best bet is open the bonnet and get someone to rev the engine the inter cooler pipe is at the front drivers side top of the radiator you may be able to pin point the whooshing sound better
Keep you fingers out of the engine bay though Thumbs Up
Post #416179 Sun Mar 02 2014 9:43pm
Sandra
Ok thanks I will try that, and let you know.
Post #416183 Sun Mar 02 2014 9:48pm
Camelrock
You don't say which engine is in your car, is it down on performance ? If its a v6 then it could be a split balance pipe which runs behind the engine .. 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
2018 Discovery 5 HSE lux current
1994 Dakar current
Post #416239 Mon Mar 03 2014 11:11am
J.blase
United Kingdom 2007 Range Rover Sport 4.4 V8 HSE Bonatti Grey
Hi sorry it's a tdv8 thanks.
Post #416352 Mon Mar 03 2014 6:12pm
Camelrock
In that case it could be warped manifolds. Something that is a known problem on the V8 engine.. 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #416416 Mon Mar 03 2014 11:09pm
