Home > Maintenance & Modifications > Aftermarket Subs
anton
Aftermarket Subs
I am thinking about putting an aftermarket sub in my sport.i heard nothing but bad things about the Logic7 so decided not to go for it.I will also be looking to upgrade the front speakers.Has anyone done this ,or had it done by a company.Dont really want to be pulling my brand new car apart for wiring and wondered if there were any specialists.Also is there a pre out on the headunit to run an amp off?
cheers
Post #49941 Sat Aug 19 2006 10:02pm
Shocked Shocked Shocked
It'll never fit
Post #49951 Sat Aug 19 2006 10:09pm
Laughing Laughing Laughing Laughing
Sometimes the most predictable ones are the best!! Thumbs Up
Post #49952 Sat Aug 19 2006 10:11pm
On a serious note anton - Personally , I find the logic 7 OK , its no worse than the systems in any of my previous Audis with Bose. I wouldn't want to pull my car apart either. But, I'm sure if you take your car to a reputable car HIFI installer you'll get just what your looking for.
Take a look at one of the forums sponsors for instance http://www.prestigeaudio.co.uk/auto/
Post #49958 Sat Aug 19 2006 10:17pm
Not forgetting site sponsors Prestige Audio, who can be seen in the banner above (when they're in the banner above, obviously). I notice they had a write up in BMW Car mag last month....
Post #49959 Sat Aug 19 2006 10:19pm
anton
Well ive always been told that if if you spend enough money anything can be done.So i will make calls as usual and see what i can find out.
Post #49960 Sat Aug 19 2006 10:19pm
I think Logic7 tops Very Happy RRS TDV6 Gone but still around
Post #49961 Sat Aug 19 2006 10:20pm
anton
cheers guys ,this is the sort of thing im after.The sub is so neatly done in the boot
http://www.prestigeaudio.co.uk/auto/bmw-x3-auto-1-24-67.html
Post #49963 Sat Aug 19 2006 10:22pm
Prestige Audio
We have an RR Sport booked in for an almost identical sub to that X3 next week so I'll stick some piccies up. Sadly there is no pre amp outputs on the standard HUs so you will need to use either an amp with a high level input, or a high to low level converter.
HTH!
C
Post #51469 Sat Aug 26 2006 3:04pm
Zipperman19
United States 2006 Range Rover Sport 4.4 V8 HSE Buckingham Blue
Yeah you could tap off the rear speaker or even the speakers in the headliner and use a high to low converter to get the low rca cables to plug into the amp. Then you need to run a cable through the firewall, under the carpet and into the back. Hook the amp up and everything should work. Front speakers are fairly easy to swap, but you may want to get a better amp on them which requires you pulling the outputs from the stock amp to your aftermarket amp. The car uses a MOST bus system so there are no speaker outputs in the headunit, just the amp.
Post #51908 Tue Aug 29 2006 11:59pm
