Home > Technical > Battery ?
Chris day
Battery ?
Please can someone help me before I muck things up!
I was thinking of changeing the battery over for a new one and need to know if it's ok to just disconect the old one' lift out and replace with the new one?
Or do I need to keep power to the leads to stop things mucking up big time?
I would Appreciate your help
Thanks
Chris.
Post #415263 Sun Feb 23 2014 11:40pm
rigsby
Hi Chris, I disconnected my old cars (TDV8) battery to charge it overnight and had no problem at all when I re connected it so you should be ok MY16 AUTOBIOGRAPHY Indus silver with some toys
2012 3.0 SDV6 Luxury gone, but a great motor
Post #415265 Sun Feb 23 2014 11:54pm
Chris day
Thanks for that. I was worried that I might get fault codes coming up and radio lock code.
But if yours was ok fingers crossed mine will be too Thumbs Up
Post #415266 Mon Feb 24 2014 12:03am
Texstar
Just one thing before you disconnect it, let the vehicle 'go to sleep', by that, I mean wait for the red park brake light on instrument cluster to go out first. Thumbs Up RRS TDV8 Buck Blue (no, not now in my dreams). ..........D3 TDclankety clankV6 ............BMW 318i
Post #415270 Mon Feb 24 2014 1:10am
Chris day
Thanks for help Thumbs Up
Should I leave the key in the ignition or take it out?
Post #415293 Mon Feb 24 2014 11:02am
Texstar
I would take the key out, and close all doors etc,( except bonnet obviously), I know you may only be changing the battery, but all the time the key is in, doors open etc, and engine not running,the battery whilst connected, will be being drained by these. Thumbs Up RRS TDV8 Buck Blue (no, not now in my dreams). ..........D3 TDclankety clankV6 ............BMW 318i
Post #415296 Mon Feb 24 2014 11:25am
Haybale
England 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Which battery did you go for?
I'm looking at changing mine, but it seems there are so many makes/models out there I'm not sure which one to go for other than H8 90 amp/hr as per the handbook..... Question
Post #416398 Mon Mar 03 2014 9:46pm
Chris day
I went for the bosh S4013 £89 on eBay. All seems ok and there are a few members on here that have used it. So I thought if there are happy I will be.
Post #416423 Tue Mar 04 2014 12:14am
SimonR
I was having starting problems at the start of the winter as the weather got colder and replaced the OE battery which still tested good for a Varta the same size - it's made a huge difference. Cost about £100 from a local motor factor - and they delivered it to me within 30 mins!
I've kept the old one and charged it - just in case it ever needs jump starting in the future!
Si
Post #416493 Tue Mar 04 2014 1:33pm
Chris day
Good idea Thumbs Up
Post #416532 Tue Mar 04 2014 5:07pm
Haybale
Nice one, cheers Thumbs Up
Post #416596 Tue Mar 04 2014 10:08pm
