Home > General > Newbie: TDV8 bought and anti-roll bar leaking.. |
Terryrrs Member Since: 25 Dec 2013 Location: Suffolk Posts: 158 |
I have just moved from a RS4 to a RRS and if nothing much goes wrong then I see it being cheaper to run and if you have come from a GTR from what I hear it should be a lot cheaper. The problem is that it seems if you get a bad " Range Rover" then they are really bad. I have been running German cars for the last 40 years and forgotten about reliability issues. Good luck, let's hope we are both not going to be disappointed as it is a great place to be in present traffic and the increase in speed restrictions.
Tue Feb 18 2014 5:37pm |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
A warrantee is a must with a Sport. Even the deepest pockets will bulk at the demands. Obviously it won't cover the anti roll bar but I would take it to an Indi and see what they say. My car was diagnosed with a leak which turned out to be a diff seal flicking oil round the actuator. It makes sense to get service work done by dealer if you want continuity but bang per buck you will get better workmanship and value from a respected Indi. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Tue Feb 18 2014 6:03pm |
Chrale Member Since: 15 Feb 2013 Location: North East Posts: 77 |
As Simple has mentioned, warranty is a must although the ARB isn't covered as stated. Had exactly the same issue when i bought my car, fortunately the garage i purchased mine from replaced it and covered costs.
Sat Feb 22 2014 8:28am |
Paul Holywood Member Since: 14 Dec 2013 Location: Hertfordshire Posts: 307 |
If you owned a GTR, and knowing you dont get much change from 10-15k for a gearbox on those, i would think your safe mate like most motors they are good until they go wrong, just get it sorted by either LR or possibly a little cheaper from an indi,and keep regular oil changes (very important), if your going to keep it a while, you will reep the benifits. if your local to me in Herts, ive got a good lad who does all my servicing at a reduced cost. he wont take on the ARB but brakes and oil, filters etc he's good. |
Sat Feb 22 2014 3:59pm |
