Home > Maintenance & Modifications > Fitting xenon headlights?
Driller
Australia 2006 Range Rover Sport TDV6 SE Java Black
Just received my new RRS. Being the impatient type, rang around Australia till i found one with the options i wanted (and a few others i might add) but missed out on the xenon headlights. Anyone out there know if it's possible to fit the xenon headlights, not the adaptive, after delivery? I can't imagine it would be too much of a problem, just curious if they required heavier duty wiring or something?
Post #49504 Fri Aug 18 2006 8:05am
You may be able to do it, but the wiring harness will doubtless need to change. Xenons require a higher voltage to work.... you might alternatively consider higher rated halogens. I went through that circus with Mrs Shmoogle's FL a while ago...
Post #49546 Fri Aug 18 2006 1:21pm
Cliff H
I have changed to xenons on my D3, it is a straight swap , no wiring mods required. Wink
I don't think they work on a higher voltage it is just the initial start up which is handled by the starter box on the bottom of the lamp.
Post #49634 Fri Aug 18 2006 5:02pm
Driller
Thanks cliff,
i guess i'll be ringing spare parts on monday to order in a set! by the way, how much of a difference did it make? more penetration or just a whiter light?
Post #49699 Fri Aug 18 2006 8:17pm
Hmm... I'm sure when I was looking into it for the FL it wasn't as simple as just swapping the bulbs. I suppose it may well be different for different cars. Let us know how it pans out for the RRS, driller... looks like a useful bit of info will come to the surface Very Happy
Post #49726 Fri Aug 18 2006 8:44pm
Will there be any issue with the heat from the new bulbs? 2005 Zambezi TDV6 - Gone but not forgotten
Post #49728 Fri Aug 18 2006 8:47pm
Cliff H
No you can't just change the bulbs, I am talking about changing the whole lamps Rolling Eyes Rolling Eyes Rolling Eyes
Still best to check that the same principle applies to the RRS Wink
Post #49740 Fri Aug 18 2006 9:00pm
Yes, what he said Embarassed
Post #49752 Fri Aug 18 2006 9:11pm
Bobby
I understand that all xenon headlights must have the headlamp spray jets installed also... . Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #49781 Fri Aug 18 2006 11:20pm
Driller
Yes indeed, was looking at changing out the whole assembly. Not really keen on aftermarket rubbish and bolt ons. Cliff, how nuch did you pay for your D3 units. Just got a quote here in oz for an absolutely ridiculous amount of money, $5000.00 each!
Post #50378 Tue Aug 22 2006 6:22am
Compuway
Australia 2006 Range Rover Sport TDV6 HSE Java Black
Heh Driller you have a PM 2006 RRS TDV6, Java/Alpaca, Dynamic Response Pack, Tow Pack, Head and Tail light protectors, 20" Stormers, Roof Rails, S/C Grill and Side Vents, Tasmods. AutoLogic mod.
1988 RR Highline, 3.5 EFI Arctic White, ARB Bullbar, Roof Rails, 15" Alloys, Front and Rear light Grilles, Side steps. (Still going strong)
Post #51024 Thu Aug 24 2006 1:24pm
RRUK
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Stornoway Grey
Isn't that more of a legal requirement rather than safety or functional? L319 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF
1982 Series 3 SWB
Post #51033 Thu Aug 24 2006 1:51pm
Singletrack
Belgium 2006 Range Rover Sport TDV6 HSE Java Black
You are correct - it is a legal requirement in Europe to have both headlight washers and dynamic height adjustments...
Illegale Xenon-Nachrüstung ist gefährlich und verboten 2006 Range Rover Sport TDV6 HSE, Java/Ebony/Cherry, Privacy, Sunroof, PTI, Premium Sound, SatNav, Cold Climate, Tow kit, CarStyle coded grill and vents, Tasmods, Stormers, JE Exhaust, Autobiography badge
Post #51082 Thu Aug 24 2006 2:53pm
Nicht auf das Gras gehen!!
Post #51083 Thu Aug 24 2006 2:55pm
Driller
xenon's
Sorry to be a bore but getting back on topic quickly, i have managed to find the information i require and will be under taking the op as soon as i get back on land. For those of you interested, see my thread in technical, part no's, and it will give more info. I'll let you get back to your banter now, boobies anyone?! Very Happy
Post #51110 Thu Aug 24 2006 4:03pm
