Home > Spotted > Java Supercharged 06 plate, Fosse Park Leicester |
MDP Member Since: 15 Jun 2005 Location: Back in an AUDI Posts: 8598 |
There is no need to lower every time - but us shorties find it easier to get in and out
Wed Aug 16 2006 1:07am |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
Cheers all - saves reading the manual again! |
Wed Aug 16 2006 8:26am |
NellyP Member Since: 26 Oct 2006 Location: Leicester Posts: 69 |
Parks in "mother & Todler" space & still needs more room, maybe al the silver colour coded bits dazzled the driver |
Tue Nov 28 2006 11:33pm |
ENVOY Member Since: 09 Nov 2006 Location: In the shit as usual Posts: 5823 |
i always lower mine, two reasons it looks good and it saves seat wear some of my Previous cars
Wed Nov 29 2006 12:22am |
landroverstormer Member Since: 22 Oct 2006 Location: Somewhere close Posts: 325 |
It also put's the car into 'sleep' mode as with P38a Range Rovers. I posted a particularly dull post about flat batteries and electronic opening devices (gates and garage doors) but I forget where it was posted.
Wed Nov 29 2006 5:06pm |
TB Member Since: 19 Feb 2006 Location: Depends who wants to know . . . Posts: 5927 |
I always lower mine. The wife is a short a**e and can't get in and out if I don't. It does get on your nerves though if someone opens the doors before it has fully lowered to access height.
Wed Nov 29 2006 11:08pm |
Singletrack Member Since: 07 May 2006 Location: Belgium - Lasne Posts: 330 |
I always lower mine also, and drop it when entering a car park, but did not know you could "lock" it in that position. How do you do this? I was warned by the dealer about accelerating while in a car park with a low ceiling as the car would then rise to regular height. I've had this happen once although the ceiling was high enough. Curious about being able to lock it. How is this done? 2006 Range Rover Sport TDV6 HSE, Java/Ebony/Cherry, Privacy, Sunroof, PTI, Premium Sound, SatNav, Cold Climate, Tow kit, CarStyle coded grill and vents, Tasmods, Stormers, JE Exhaust, Autobiography badge |
Thu Nov 30 2006 7:13am |
To lock it in access height, you keep your finger on the button and it'll go bong. When you then subsequently drive over a partic speed (I think it's about 10-15mph) it unlocks itself and returns to normal height.
Thu Nov 30 2006 9:41am |
Thu Nov 30 2006 9:57am |
I also always lower the RRS and did the same with the FFRR. To get round the "somebody opens the door before it has finished lowering" situation I press the button earlier than needed so the car is lowered before I stop. There is no problem with driving slowly in lowered mode - IIRC LR designed the suspension to operate in access mode for use in low multistorey carparks. The problem I have is getting the other person who occassionally drives my car to lower the suspension before leaving it locked for long periods. So far no flat battery ..... 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thu Nov 30 2006 11:02am |
MikeP Member Since: 18 Dec 2006 Location: Buckinghamshire Posts: 258 |
Hi guys sorry to revive an old topic but I have one question. When you say someone opens the door before its had time to lower...does it not wait and when you've closed all the doors then lower itself? Then you can lock it? I know with my mates RR Vogue TD6 that whenever I drive it, I lower it get out and lock it and it continues to lower. At least I'm pretty sure it does. Cheers Mike |
Mon Dec 18 2006 10:10pm |
Kaine Member Since: 27 May 2006 Location: Hills of Shropshire Posts: 8902 |
nope - once you've removed the key and opened the door it doesn't continue to lower |
Mon Dec 18 2006 10:13pm |
Oh ok..thanks for correcting me on that one. I wasnt 100% sure...I think my eyes need checking
Mon Dec 18 2006 10:19pm |
I do the same! Usually while waiting for our gate to open or while crawling around searching for a parking space. 2006 Range Rover Sport TDV6 HSE, Java/Ebony/Cherry, Privacy, Sunroof, PTI, Premium Sound, SatNav, Cold Climate, Tow kit, CarStyle coded grill and vents, Tasmods, Stormers, JE Exhaust, Autobiography badge |
Mon Dec 18 2006 10:26pm |
