Home > Technical > heater fan problem
airwolf222helicopters
heater fan problem
hi all wonder if any you guys can shed light on this
heater fan /blower not working on my 07 rrsport
all lights work when switch is turned from 0- max but no fan ???
looked at some of the threads on here and have replaced relay 16 with fan icon on engine bay fuse box but am confused as still not working ?
a mention of checking FL12 ? is this a fusable link ? in engine bay fuse box ??
anyone had this and got the solution ???
much appreciate any advice
Post #407961 Fri Jan 03 2014 6:58pm
anyone??
I cant be the only one to have this happen
found the fl12 fuse and was fine
do you think it could be the motor if so is it in footwell on passenger side , or is there a resistor on it somewhere?
there must be a lr tech on here who could look up for me ?
Post #408138 Sat Jan 04 2014 10:19pm
Paddi
Sorry but no good ideas to offer. You can see the fan assembly if you drop the lower glovebox by pressing down on the supporting arms. Look online for a video on changing the cabin filter to see how this is done. I'd guess any ballast resistors to control fan speed are incorporated in the HVAC unit. There is a self test routine for the HVAC you can invoke: searching the site should find the instructions. 2008 MY Java Black TDV8 HSE
Post #408177 Sun Jan 05 2014 12:37pm
Thanks for reply paddy
I have stripped out glove box and removed heater fan and connected two wires to a 12v supply and the fan spun up so its not the fan
Then followed wires down to a resistor pack controll module and I have put a multi meter to cables and get a voltage reading up and down when dial on dash is turned so , power to it, but no power out of that module
So I'm assuming its this little Censored Thumbs Up
Post #408221 Sun Jan 05 2014 6:34pm
Forgot to say I wont be able to tell if it is the solution until I get a replacement tommorow
Post #408226 Sun Jan 05 2014 6:46pm
Paddi
Top work. Looks as if you have tracked down the problem. 2008 MY Java Black TDV8 HSE
Post #408231 Sun Jan 05 2014 7:25pm
bl74beano
Australia 2007 Range Rover Sport TDV8 SE Atacama Sand
did it work?
Hey Airwolf I seem to have the same problem did your fix work?
Post #466769 Tue Jul 07 2015 5:00am
