Home > Maintenance & Modifications > Air Suspension Renewal
Tommyschuck
2007 Range Rover Sport TDV8 HSE Sumatra Black
...does it make sense to change all 4 dampers at the same time?? Or is it just a waste of money, because they last almost a lifetime?? I got 100.000km on my RRS 2007. Any thoughts?
Post #406489 Tue Dec 17 2013 4:45pm
shepp
If you change the entire strut, air spring and shock should make a difference, but only if you have replaced worn upper and lower arms. Doing them yourself can be a bit of fun, should cost around £800.
Post #406532 Tue Dec 17 2013 10:12pm
Leon1551
United Kingdom 2006 Range Rover Sport TDV6 HSE Santorini Black
Air suspension compressor
I have a 2007 RRS and for a while the wobbly vehicle orange warning sign has been on, about 2/3months ago a warning came up normal height only "suspension fault" but I was able to adjust suspension manually. Last week while driving home the warning has now started flashing and I cannot adjust suspension manually or remove the warning off the dashboard.
I have Been told it's the air compressor but also told to use a fixing kit first as these compressors are approx £600.
Can anyone shed some light or advise on what to do. Also recommend retailer that sells compressors.
Cheers leon
Post #408327 Mon Jan 06 2014 1:55pm
shepp
 hello your issue may be an internal leak on your compressor, caused by a weak exhaust valve. My rrs started by intermittantly flashing up amber with the suspension fault. I fixed mine 2 years ago and not had any issues. Its also is worth checking the wiring in the front wheel arch. Just requires a few upgrades to the compressor, also it would be worth drying out the air dryer at the same time. The TSB below explains how to upgrade the compressor.
 http://www.rrsport.co.uk/gallery/albums/us...rogram.pdf
It is a fairly easy job if you have some decent tools and a small two arm gear puller (use it to remove and replace the exhaust valve cap) The below is the repair kit, can also be purchased from the dealers
http://www.brit-car.co.uk/product.php?xProd=139015 this is a quick guide from the disco 3 site on how to remove the compressor
http://www.disco3.co.uk/forum/topic67721.h...eplacement
 use pleanty of penetrating oil on all connectors befor removal
Post #408348 Mon Jan 06 2014 5:13pm
duckworthparts
Site Sponsor
compressors we can do to forum members for £450inc vat delivered Sophie Alltoft
Send a paypal payment direct using this link www.paypal.me/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: danroberts@duckworthlandrover.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Can also supply OEM & Aftermarket parts
Post #408351 Mon Jan 06 2014 5:22pm
