Home > General (L494) > Engine oil level not available |
Bob, i don't know if this will work on the RRS2 but it does on the original RRS. Try lifting the bonnet, then see if the oil level check is available. Hope this helps. |
Mon Nov 25 2013 9:30pm |
peanutbob Member Since: 04 Jul 2011 Location: UK Posts: 585 |
No, I've decided to put a long straw in the filler cap instead...that should do the trick! Give or take a few litres here and there! |
Mon Nov 25 2013 9:35pm |
East Coast Sport Member Since: 23 Jul 2013 Location: Angus Posts: 78 |
On mine the ignition has to be switched on, but the engine has to be stopped. It doesn't work with engine running. Its worth a try. 2017 3.0 SDV6 Autobiography Santorini Black
Tue Nov 26 2013 9:32am |
Also needs to be warm but 10 minutes or something like that, after the engine first ran.
Tue Nov 26 2013 10:23am |
Thanks...I've done all that..engine warm...turned off ignition, waited 10 mins...but it doesn't work!
Tue Nov 26 2013 10:34am |
Checked the level at stone cold this morning, and it worked! Went out for a 10 minute drive, parked up and returned to vehicle 45 mins later and it came up with engine oil level not available. Car was in park mode.
Tue Nov 26 2013 1:21pm |
