Home > General (L494) > Timed climate on the AB |
peanutbob Member Since: 04 Jul 2011 Location: UK Posts: 585 |
Also on the climate menu, does anyone have or have not 'rest heat' ? According to the manual this is only available on vehicles fitted with an auxiliary heater. So, as I don't appear to have that or timed climate, is the aux heater fitted as standard (presumably so...as it is on Discos and prior RRSs etc) or is there a cold climate pack as an extra?
Sat Nov 23 2013 11:03pm |
Following received from Jason Stuart at JLR:
Tue Dec 10 2013 10:44am |
malcolmw Member Since: 05 Dec 2013 Location: United Kingdom Posts: 122 |
I think that the reply above is correct. I opted for the remote heater pack and can access the timer menus from the touch screen as well as switch on via the remote control.
Tue Dec 10 2013 11:01am |
Easy way to say you have shed xxkg - don't fit anything and make it an option Mike
Tue Dec 10 2013 6:18pm |
