Home > Faults & Fixes > Suspension fault.. replacement seal kit from landyair ?
Montythegod
United Kingdom 2006 Range Rover Sport Supercharged Rimini Red
First time I sign into RRSPORT.co.uk for a while and I end up with suspension fault, have I been jinxed??...
Anyway upon further investigation, I found the compressor pumping constantly and even after turning off ignition it continued, left it for 10 minutes still pumping flipped bonnet and tapped the relay and stopped it... soo dodgy relay ? swapped with rear screen heater relay (same part number and next to it), Jumpstarted car due to now flat battery and now have the following GAP diagnostic codes even after clearing :
5131 - Air Supply
5A20 - unknown
Air suspension inactive and seemingly pointing to a new compressor (that is still operational and buzzing away from time to time) from what I can make out, question to the forum people, before I replace the compressor has anyone had any experience of the seal replacement kits from http://landyair.com/ ? they seem genuine with instructional videos etc..
unless any has any suggestions for refurb / exchange of the compressor ? If I need to buy a new one and upgrade the software then I will, but need to explore all options first... Why?.. Because i can....
RRS 2006 S/C Rimini Red Weekend toy
Subaru impreza 1998 2.0 340hp still here
Smart car 0.7 61 hp Carbon offset
Sierra cosworth 2.0 350 hp GONE
Various RS escorts, Vauxhall sri's Volvo T5's, BMW 3 series, fiestas (?) fiat's....
Mr Mischief - www.mischief-inc.co.uk Wink
Post #402384 Sat Nov 16 2013 11:55am
SCdavies
England 2006 Range Rover Sport Supercharged Zambezi Silver
I thought about this option but decided against it as I thought it was a false economy as I had the old version of pump and one day I would have to replace it any way as life expectantly is 60000 miles. I got new one and did nt need the software upgrade so that saved a few quid. Got mine at duckworths this was the cheapest. But saying all that if you have time to fiddle try it. You can also buy the plastic piston kit. Good luck.
Post #402389 Sat Nov 16 2013 1:31pm
Montythegod
found new problem with suspension
Decided to go down the refurbish route ordered and received the new seal and air dryer overhaul kit from Landyair, sent through very quickly... stripped down and replaced seals as per the online videos, noticed a better seal with kit so all looked promising, went to reinstall and found another problem Big Cry Big Cry Big Cry
the larger top air hose has a hole in it, seems to have been rubbing on what looks like a handbrake cable...its just after the bend where its inserted in the compressor, any ideas on repair or how much hard work to replace the pipe ??? ( and of course the parts required?)
It seems too close to 2 bends to cut and fit a joiner Big Cry Big Cry Why?.. Because i can....
Post #403377 Sat Nov 23 2013 5:24pm
cheet
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Lux Fuji White
Hi
I had same problem with compressor constantly running.
Found air leak that had caused the compressor to basically burn out.
Purchased the piston seal kit from landy air and changed the seal.
All isl working fine now.
Post #403534 Mon Nov 25 2013 6:01am
Montythegod
Where was the air leak and what did you do to repair ? Why?.. Because i can....
Post #403588 Mon Nov 25 2013 4:58pm
cheet
The air leak was on the connection where the small pipe from the compressor enters the air drying unit.
I just sprayed soapy water all around the area wherever there`s any sort of connection and looked for the bubbles.
Post #403648 Mon Nov 25 2013 11:51pm
Montythegod
We'll suspensions now all sorted, took it to the guys at RCV at East Peckham nr tonbridge who kindly replaced the compressor and repaired the damaged pipe work... Decided although the pump was refurbed it may only be a matter of time before it would need replacement..
Had all ecu soft wares updated too and the rrs drives better and seems more economical as a result! Thumbs Up Thumbs Up
Had to mark myself down on man points tho as it the first time in 22years of motoring I have ever paid a garage to fix a car for me Big Cry Big Cry Why?.. Because i can....
Post #404161 Thu Nov 28 2013 9:58pm
Bodsy
Site Sponsor
Monty, do you have the old compressor still? Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #404162 Thu Nov 28 2013 10:01pm
Montythegod
sorry I forgot to ask for it back and the garage is well out of my way to go get it Sad Why?.. Because i can....
Post #404165 Thu Nov 28 2013 10:12pm
Bodsy
Site Sponsor
No problem, just a thought Thumbs Up Bodsys Brake Bible
See it HERE
Post #404166 Thu Nov 28 2013 10:15pm
Montythegod
I have sent an email to see if they are willing to ship it to me Smile will let you know Why?.. Because i can....
Post #404167 Thu Nov 28 2013 10:17pm
PEACHY
Bodsy - I have my old EAS compressor Question 16MY Estoril Blue SVR.............
Post #404168 Thu Nov 28 2013 10:17pm
Bodsy
Site Sponsor
Peachy, would be useful to have a play with it Thumbs Up
Monty, Thumbs Up Bodsys Brake Bible
See it HERE
Post #404169 Thu Nov 28 2013 10:22pm
PEACHY
Shocked what about the compressor Rolling with laughter Rolling with laughter Thumbs Up 16MY Estoril Blue SVR.............
Post #404170 Thu Nov 28 2013 10:24pm
Montythegod
after spending 80 quid on the new seal and air dryer I hope I can get it back Smile Why?.. Because i can....
Post #404171 Thu Nov 28 2013 10:25pm
