Home > Technical > Help and advice needed |
& I thought I had it bad sorry to hear of your constant problems - had a similar fault - it was a cheap fix - a temp sensor in the coolant hose ( I've changed EAS compressor & battery & alternator ).
Sun Nov 03 2013 8:35pm |
Tigerdon Member Since: 28 Sep 2013 Location: Belfast Posts: 35 |
Big time my problem is I've had very few opportunities past while to say it's anything apart from dung
Sun Nov 03 2013 8:58pm |
Fluctuating revs can be a sign of torque converter on the way out but before jumping to that conclusion and bearing in mind the other suspension issues I'd start with having the fault codes read and check some of the usual suspects like brake light bulbs and brake light switch. 2008 MY Java Black TDV8 HSE
Sun Nov 03 2013 10:37pm |
But there are no codes showing mate |
Sun Nov 03 2013 10:44pm |
So you have plugged in a LR specific diagnostic fault code reader and there are no faults logged right? 2008 MY Java Black TDV8 HSE
Mon Nov 04 2013 1:35pm |
Was up at Indy specialist today they said its a transmission fault
Mon Nov 04 2013 1:39pm |
What fault codes if any did they find that points to a gearbox fault?
Mon Nov 04 2013 2:17pm |
Yes it's Dr Tranny the additive they referred to
Mon Nov 04 2013 4:28pm |
Were can u change the torque Convertor only? I've been told it can't be bought as a separate unit
Mon Nov 04 2013 5:12pm |
Oh yes they can; because I've just had one fitted
Mon Nov 04 2013 7:49pm |
I should know tomorrow if this Dr Tranny works r not
Mon Nov 04 2013 8:00pm |
Replied to your PM.
Mon Nov 04 2013 8:28pm |
What was up with yours fella? |
Mon Nov 04 2013 8:35pm |
You could always try a auto-box stall test.
Tue Nov 05 2013 1:36pm |
