Home > Technical > Sat Nav on the move
Josh
Sat Nav on the move
I know this has been mentioned before and I know some of you say it doesn't work on the move.
BUT yesterday I was driving along realised I hadn't started it. So turned it on, selected a previous destination, chose a route and off we went. Sat nav working on the move.
So is there some part of it that dosen't work Question and I'm missing the point Exclamation or did the latest software upgrade fix it Question TDV6 - gone
TDV8 - gone
Post #47590 Thu Aug 03 2006 9:42am
Funny you should mention that Josh.... this happened to me the other day too. I wanted to set a route after I'd actually set off and tried and voila! it worked where it certainly never used to. I haven't had any updates done though.
Post #47592 Thu Aug 03 2006 10:00am
p-trax
I think the only restrictions are entering a new address/postcode whilst in motion. If you recall a previous entry or a strored (ie HOme) address then it all works fine. The further restriction is that you cannot scroll through previous entries, so you only see the last 4 Smile Stornaway Grey/Ebony TDV8 HST, September 3rd Smile
Post #47596 Thu Aug 03 2006 10:16am
That would make sense... I was using the home destination...
Post #47600 Thu Aug 03 2006 10:35am
I sure the latest update fix this RRS TDV6 Gone but still around
Post #47603 Thu Aug 03 2006 10:40am
