![]() | Home > In Car Electronics > Sat Nav reboots - Seems to be when it is cold. |
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916
Sounds like a power issue to me
| Steven D Member Since: 08 Oct 2013 Location: Lancashire Posts: 19
Thanks for the reply.
Rather than thinking does the sat nav need more power when cold - its more, does the car have enough power to support the car.
| Dhups Member Since: 15 Sep 2013 Location: Essex Posts: 183
I get this issue too and only when its a cold morning.
Hi Mike,
Yes ultimately it could be anything - but given the battery and alternator issues are usually minor faults and cause weird major issues - i would start there, rather than wiring that hasnt ever moved. Although i can imagine things like earth connections could all come into play.
Cheers again for your reply Mike.
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563
Steve,
Cheers Paddi for the advice.
| finbarfinnegan Member Since: 26 Aug 2011 Location: Banbridge Posts: 19
Hi Steve.
Hi Steve,
It all actually started after the alternator burn out. It didn't happen before that.
Hi Tim (apologies for writing Steve last time!!! |
| planko Member Since: 23 Nov 2013 Location: Perthshire Posts: 1
Hi. I had the same issue after alternator burnt out. Power would pulse as soon as i turned the ignition key then go away after a couple of revs.
| All times are GMT |
