Home > General > Range rover sport pulling massively to the left... |
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5584 |
Sounds like a tracking issue - maybe bent tracking rod or similar Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Mon Oct 07 2013 3:49pm |
Did you find a solution to this? Seems odd if you have had a 4 wheel alignment check and no improvement. Did the alignment check show that adjustment was required and did they adjust anything?
Wed Oct 09 2013 7:02pm |
Kenzi Member Since: 24 Jun 2013 Location: Perth Posts: 101 |
I don't imagine it would be but a bush failing will put your steering way out! |
Thu Oct 10 2013 8:24am |
ajp166 Member Since: 10 Jul 2011 Location: london, UK Posts: 241 |
Guys I just checked pressures.. That wheel was only 19 psi so it's losing air I put the pressure back to 35 but it still pulls to that wheel side. Tyre shop ha looked at it so now I'm confused especially as I just put air in and still same problem. |
Sun Oct 13 2013 2:02pm |
^^ What did the tyre service place say about the cause of loss of pressure? Did they do anything other than 'look at it"?
Sun Oct 13 2013 2:47pm |
When u say the inner rim do you mean the tyre or actual alloy wheel? |
Sun Oct 13 2013 5:59pm |
nicedayforit Member Since: 12 Mar 2012 Location: Beside the Solway Posts: 25 |
You don't have a brake caliper binding on the front left wheel by any chance?
Sun Oct 13 2013 6:13pm |
The wheel. With tubeless tyres which we all drive on, the ability to retain pressure relies not just on the tyre but also the integrity of the wheel itself.
Sun Oct 13 2013 6:19pm |
At a tyre specialist now.. Rim is fine and fully inspected, tyre is also fine so they think maybe the valve so they replacing and will glue around edge of rim they say this should all be fine then. I will soon find out I guess. |
Mon Oct 14 2013 12:42pm |
Good. From a safety point of view it's well worth knowing that the wheel is not cracked and is running true. The new valve and bead sealant should certainly fix the pressure loss. If you still have pull to the left then obviously will need to investigate further.
Mon Oct 14 2013 12:57pm |
Thanks for the reply.
Mon Oct 14 2013 2:07pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8863 |
Time to get a 4 wheel alignment done. Make sure they set the EAS to tight tolerance mode. Is the vehicle on wheels >20 inch diameter? 2012 SDV6 - it's missing a couple of cylinders
Mon Oct 14 2013 5:37pm |
Guys its started pulling again to the left and the tyre pressure is going down... Im thinking to just get two new tyres at the front? or should I swap the rears with the fronts? |
Thu Nov 28 2013 6:37pm |
It has 22 inch wheels.... I had the alighnment done but its still the same problem... |
Thu Nov 28 2013 7:02pm |
