Home > General > towing capacity detatchable tow hitch |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8856 |
3.5 tonnes. The maximum nose weight is 150kg I think.
Sat Oct 05 2013 10:29pm |
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5584 |
http://www.towcar.info/advise_2.php?merk=L...;periode=0
Sat Oct 05 2013 10:33pm |
The "85% rule" is a Caravan Club recommendation for single axle caravans rather than twin axle utility trailers isn't it? 2012 SDV6 - it's missing a couple of cylinders
Sun Oct 06 2013 8:50am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4345 |
For occasional towing, the QR one will be fine.
Sun Oct 06 2013 8:55am |
Not surprised D_M, the QR ball does have a tiny bit of play so I could see that continued movement in use would be quite damaging. If and when SWMBO gets her horse to the stage where we're taking it out on a regular basis in the trailer, I shall be having the multi height bar fitted. 2012 SDV6 - it's missing a couple of cylinders
Sun Oct 06 2013 9:00am |
It happens more often than you would think |
Sun Oct 06 2013 9:15am |
The 85% guide is a safety recommendation and if you are a novice worth considering for any trailer
Sun Oct 06 2013 9:45am |
mark b Member Since: 29 Sep 2013 Location: stoke Posts: 17 |
i only tow this trailer maybe 10 times a yr |
Sun Oct 06 2013 9:51am |
Muddy, I'm not knocking your post or disagreeing with your basic position.
Sun Oct 06 2013 12:23pm |
I get that and never crossed my mind Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Sun Oct 06 2013 1:01pm |
Sun Oct 06 2013 3:50pm |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1061 |
In Aust our RRS are rated to tow 3500kg with a max tow ball weight of 350kg. Our cars don't have any problem towing at these weights for extended periods but as the UK tow bar is considered inadequate for our needs LR Aust provides a different two part bar that is fitted into the standard fitting in the rear cross member.
Mon Oct 07 2013 3:54am |
Streaky Member Since: 31 May 2010 Location: Dubai Posts: 259 |
If only the Mitch Hitch was allowed in the UK....we have some here in the UAE....best for towing, recovery points etc.....but the UK is wuss on such things. Ra-Ro Sport Super Dooper Charged.
Thu Oct 10 2013 8:22am |
