Home > Technical > egr fault = loud hissing noise when taking foot off the gas
dal1557
how can you tel what egr valve is playing up ? is there a diagnostic test that can be done ? D Ledingham
Post #393899 Thu Sep 05 2013 8:58pm
simple1
There is but it involves using a diagnostic tool. Obvious answer would be have a look and see which one is the most discoloured and black? Unless you are intending to go Switzerland, why not take the opertunity to bin them? Whistle 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #393900 Thu Sep 05 2013 9:04pm
If you lift the bonnet, then get someone to switch on the ignition you should hear two clicks, one on the left hand side of the engine and one on the right, if you only hear one click, then chances are there is one that isn't working, the one that doesn't click. Thats the easiest way of checking. The lack of power and plenty of black smoke out of the exhaust is also a tell tail sign that one or even two of the egr's are not working. It could also be the egr cooler that is leaking another common problem on the older models. Sad
Post #393901 Thu Sep 05 2013 9:05pm
Disco_Mikey
AS you have an 05, just blank them. Thumbs Up
If you replace them, they will only break again. With blanking, it's much cheaper, easier, and EGR failure will never let you down again Thumbs Up
Post #393918 Fri Sep 06 2013 6:19am
c15ebb
I done this... blanked mine...a while ago now... cant remember.. would i of actually removed the vavles when i blanked them? Can remember some sort of pipe work etc i removed... but i get the loud hiss noise aswell... i didnt straight after i removed them... more so when i put de cat pipe on and full exhaust system
mines a 05
Post #394165 Sat Sep 07 2013 12:40pm
sellick
You can remove them completely, or just blank the pipe off to stop them from functioning. Presumably you just fitted 2 blanking plates?
Post #394179 Sat Sep 07 2013 1:55pm
Disco_Mikey
Can do it a few ways Thumbs Up
Stick a pair of plates between the valve and pipework
Remove the pipework and bolt a plate onto the top of the valve, and another onto the inlet housing
Remove the pipework from the exhaust manifold and blank there, so it doesn't go through the EGR cooler, and blank the holes in the inlet housing, and remove the EGR's altogether. This also give the option to do away with the EGR coolers too
All have the same effect, and is down to personal preference, and budget Thumbs Up
Me personally, I blanked mine at the exhaust manifold, and removed all the pipework and valves, with the view to doing away with the EGR coolers too Thumbs Up
Post #394256 Sat Sep 07 2013 9:42pm
c15ebb
howcome i get hissing noise now then.. sounds cool though... garage says isnt the turbo
I think i blanked mine and removed pipework
Post #394348 Sun Sep 08 2013 10:49pm
flack
If your getting a hissing noise then it must be sucking in air somewhere, if you have fitted the blanking plates to butterfly housing then check there that its not leaking had a few leaking from there with a cut o'ring. And did you remove the butterfly valve from the spindle.
Flack Thumbs Up
Post #394349 Sun Sep 08 2013 11:17pm
Disco_Mikey
Does it sound a bit like a dump valve, but a lot quieter?
My car does it, the OP's car does it. After driving a load of other TDV6's, they all do it too, but it is very faint
Post #394356 Mon Sep 09 2013 6:34am
dal1557
Dose removing the egr not effect the car in any way? D Ledingham
Post #394390 Mon Sep 09 2013 4:13pm
c15ebb
disco... yeah kinda dump valve noise... its hearable with radio off.. not mega loud like a dump vavle... only does it off throttle really if i gas it to say 3,000 rpm and let off it goes hisssss for like a second
Post #394415 Mon Sep 09 2013 6:32pm
Disco_Mikey
Removing the EGR on an 05/06MY car does not affect it in any way, shape or form Thumbs Up
c15ebb, its completely normal. After putting my Disco on the road, I heard that noise, and was starting to worry about it, until I drove a few other TDV6's and they all made the same noise. Set my mind at ease! Laughing
Post #394459 Tue Sep 10 2013 6:39am
