Home > General > IGNITION FUSE - where is it!!
andrew kennedy
France 2006 Range Rover Sport TDV6 HSE Maya Gold
I need to put a wire onto the ignition fuse in my 2006 Sport. Can anyone tell me where it is located!! Andrew Kennedy
Post #389759 Wed Jul 24 2013 9:38am
MAW
Fuse box....
Whistle
Laughing
Post #389768 Wed Jul 24 2013 10:36am
andrew kennedy
Fuse
MAW wrote:
Fuse box.... I know there are two fuse boxes and where they are located. Do you know which FUSE and in which box I can find the one covering the ignition?!?
Whistle
Laughing
 Andrew Kennedy
Post #389773 Wed Jul 24 2013 11:18am
sparky8181
The fuel pump fuse is on the ignition live, and is located in the engine bay, you can use this with a piggy back fuse carrier and it will give you an ignition live if your fitting something in the engine bay.
Not sure about the other fusebox but sure there will be plenty of ignition live fuses in there if you test them Thumbs Up
Post #389777 Wed Jul 24 2013 11:52am
flack
Get a piggy back fuse from Fleabay and use fuse 58 in the lower glove box, just insert the piggy back and another fuse for your supply this will be live when you turn on your ignition.
If you want a permanent live then use fuse 41in the same place
Flack Thumbs Up
Post #389790 Wed Jul 24 2013 2:35pm
andrew kennedy
PIGGYBACK fuse
Thanks for the info. I can see exactly what I need to do. To save the problem of tracking the wire from the car interior through to the engine bay, is there any fuse I could use in the 'engine compartment fuse box'? Andrew
Flack Thumbs Up
 Andrew Kennedy
Post #389885 Thu Jul 25 2013 9:32am
sparky8181
"Thanks for the info. I can see exactly what I need to do. To save the problem of tracking the wire from the car interior through to the engine bay, is there any fuse I could use in the 'engine compartment fuse box'? Andrew"
Banging Head Banging Head Banging Head Thud
I already said the fuel pump
Post #389886 Thu Jul 25 2013 9:36am
flack
Yes just get a dvm and check some of the empty relay positions in the fuse box next to the battery there are a couple in there that work with the ignition on or off, then just use a flat spade connector to insert in to the feed and then branch off that with a inline fuse to what you want to feed.
This post by Wiggs should help you..
http://www.disco3.co.uk/gallery/displayima...&pos=2
Flack Thumbs Up
Post #389889 Thu Jul 25 2013 10:02am
andrew kennedy
Yes just get a dvm and check some of the empty relay positions in the fuse box next to the battery there are a couple in there that work with the ignition on or off, then just use a flat spade connector to insert in to the feed and then branch off that with a inline fuse to what you want to feed. THANKS FOR THAT !!
Flack Thumbs Up
 Andrew Kennedy
Post #389893 Thu Jul 25 2013 10:17am
