Home > Faults & Fixes > Alignment rivits
looneyfitter
2005 Range Rover Sport TDV6 HSE Alaska White
Alignment rivits
Hi took my car in to be aligned. I was told it can't be done as the rivits that should be by the adjustable cams are missing? Does anyone have a pic of what I'm lookong for please? I have to weld some or something.
Kind regards
Post #387461 Mon Jul 01 2013 12:36am
flack
It is a notch on the chassis that the cams rotate on so that the adjustment can be made some have been found to have been ground off.
Flack Thumbs Up
Post #387477 Mon Jul 01 2013 9:33am
Bodsy
Site Sponsor
i've know a few people to weld a spot on in it's place which has worked OK. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #387482 Mon Jul 01 2013 11:09am
flack
As Bodsy says get something welded on in its place as long as its able to turn the against the eccentric washers you should be fine.
Flack Thumbs Up
Post #387500 Mon Jul 01 2013 3:10pm
looneyfitter
Cheers lads any pics? There's a few washers from what I can see. Not sure where to weld
Post #387508 Mon Jul 01 2013 5:01pm
flack
This is a view of the front drivers side lower front bolt you can see the washer hits the notch so when you turn the bolt it moves it off center.
Flack Thumbs Up
Post #387513 Mon Jul 01 2013 6:55pm
looneyfitter
Cheers Flack. Are the rears the same? Mine has got them rivits so not sure what alignment place is on about now. Also on the front lower wishbones should the nut be front or rear?
Cheers mate
Post #387532 Mon Jul 01 2013 10:04pm
flack
All the ones I have changed have the nuts at the front just like my picture..
Flack Thumbs Up
Post #387539 Mon Jul 01 2013 10:24pm
looneyfitter
didnt realise you had replied to this. Thanks Flack
Post #432724 Sat Aug 09 2014 11:38pm
